Old 03-04-2021, 03:32 PM
cgeyman's Avatar
cgeyman cgeyman is offline
Default RV-9a: Calís build
Hi all. I am building a QB rv-9a at our eaa 517 hanger here in Missoula MT. I finished most of the tail (still have left elevator trim tab), and am working on the fuselage. The Philippines QB trip did result in some surface corrosion which I must remediate, but Van’s has been helpful on this. I am planning an o-360 carbureted lycoming with a fixed composite prop, and will respect Vno/Vne/Va speeds as I hate the idea of pilot induced trouble. Anyway, hope to post how it goes.
Please click on the Flickr link below to view photos of my build.
Old 03-04-2021, 03:46 PM
cgeyman's Avatar
https://flic.kr/p/2kH5TYv
You can scroll left or right to see photos of the corrosion coming back from the Philippines. But again it can be remediate and Vans is correcting the situation.
Old 03-04-2021, 09:46 PM
Steve Melton's Avatar
nothing to worry about. scuff and paint and move on.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 03-05-2021, 07:43 AM
Agreed nothing to worry about. Good luck on the build thatís a pretty place in Montana you are living in.
Old 03-05-2021, 08:21 AM
cgeyman's Avatar
Thanks Steve and Vlad. In the beginning you tend to catastrophize every little imperfection.
Thanks for the support and welcome!
Old 03-09-2021, 03:57 PM
cgeyman's Avatar
Default Steps
http://https://www.flickr.com/photos/192383868@N06/shares/XHtsbP
Old 03-25-2021, 08:43 PM
cgeyman's Avatar
Arrow Seats
https://flic.kr/p/2kP67hC
Old 03-25-2021, 08:46 PM
cgeyman's Avatar
Default Cabin tunnels and fuel lever housing
https://flic.kr/p/2kGYuRp
Old 03-25-2021, 08:47 PM
cgeyman's Avatar
Default Flap actuator arm
https://flic.kr/p/2kP66NM
Old 03-29-2021, 04:45 PM
cgeyman's Avatar
Default Flap motor
https://flic.kr/p/2kPZof6
