Old 03-23-2017, 12:29 PM
Toobuilder's Avatar
Default SDS CPI Tricks and Tips
As some of you know I am a very happy user of the SDS CPI product. I have several threads on this and other boards documenting the installation, tuning, and general observations of CPI, and I will continue to help out when I can in the future. I also get PM requests for help and am happy to do so. In the spirit of useful information I thought I would throw together a quick list of common CPI errors and installation tips in this thread.
Keep in mind that this thread is intended to be CPI specific, and covers the problems/tricks I have seen. In many cases, these are covered clearly in the manual but consider this a “foot stomp” requiring extra attention.
Magnet position: The CPI needs to see the synchronization magnet before it derives the firing angle. The magnet position IS UNIQUE TO EVERY INDIVIDUAL ENGINE! Despite the fact that there is a beautiful machined billet hall sensor mount and a precision magnet drill position fixture, the relationship between the engine’s TDC, hall sensor and magnet location on the ring carrier is subject to significant variation. There are a lot of machined holes between the engine and CPI components that define this relationship, so that means a potential for lot of “tolerance stackup”. Also keep in mind that even in a perfect world, there will still be a different magnet position between the first and second pickup of the dual hall sensor (because one is further away from TDC than the other), and the single hall sensor, which will roughly split that difference. Yes, the default magnet position is close, and you can quickly adjust the “timing” with the up/down keys to achieve a beautiful idle, but the timing “value” displayed is likely to be off by 5-10 degrees. It will be worthless as a reference. So to foot stomp this one point – The magnet position MUST be set before flight. Fortunately, it’s a very easy process. Set the engine to a convenient mark on the ring carrier (TDC, 10, 20, etc) and place a pointer in any easy to access point on the engine, make a mark on the gear with a piece of tape and a Sharpie corresponding to the pointer, and grab your trusty automotive timing light (remember those?). With the timing light set up on #1, set the idle RPM advance on the CPI window to match your selected timing mark. Assuming you went with 10 degrees advance, set 10 degrees in all RPM ranges up to about 1200, and zero out the MP advance. Select the magnet position window on the CPI and plug in the default shown in the manual (should be 80 – 90), start the engine and aim the timing light at your temporary pointer. If the mark and pointer align, you got lucky and you are done. If not, simply key the up/down arrow a few times until you drive the mark into alignment. You are now done. Look at the value displayed in the window and record it in your logbook, because it’s permanent to your engine combination. Note that if you have a dual hall mount sensor, you will also have to set the other set of pickups too. DO NOT simply duplicate the mag position setting from one CPI into another. Setting the magnet position takes only seconds to do and forms the basis for all other timing, so don’t skip it.
Drilling the ring carrier: Drilling the holes for the magnets is easy with the provided drill guide. So easy, it can be done without removal from the engine in many cases. That said, the old adage to “measure twice and cut once” applies here. It’s a bit hard for some of us to get our head around the relationship between the sync and trigger magnets and their location around the ring carrier, and I’m not the only one who has a few “extra” holes… My advice to all of you out there is to slow down, study the installation manual, and when you think you are ready to drill, STOP, and use a Sharpie instead. “Drill” and label your holes with a Sharpie and then go to bed. The next day, compare your artwork with the illustration in the manual with a fresh set of eyes. If it matches, fire up the drill and go for it.
Ignition tuning: Set with the defaults, the CPI provides all the performance benefits of any electronic ignition and works beautifully. However, unlike the other offerings, CPI offers essentially infinite adjustment of timing so that you can tailor it to YOUR airplane and YOUR mission. Despite the myriad of adjustments, you do not have to be a test pilot to find the optimum setting. I have found that one of the clever features of the CPI has an unintended benefit – a way to safely “backdoor” test settings. The LOP feature instantly adds a user definable advance value with the flip of a switch, which also means that you can instantly REMOVE this value if something doesn’t go the way you like. This provides a very safe way to sneak up on an advance setting in flight because it gives you an instant return to a known, safe condition.
To illustrate a very conservative approach to finding a “ROP, cross country cruise” (for example) setting: On the ground, set up the RPM advance to max out at your data plate setting (25 degrees, for example), and zero out (disable) any MP advance. Now you are flying with your engine manufacturers known “safe” condition and can play from that position of certainty. Climb to altitude (7500, for example) and set power, mixture, and let it stabilize at speed. Once satisfied with your “normal” speed, record that value, and all other pertinent engine values, as well as your timing as shown on the CPI window (should be 25, in this example). With data recorded, select the LOP window on each CPI and set it to “1” (degree). Now flip the LOP switch and see what happens. If everything looks good, let that setting stabilize (at least 5 minutes) and record the timing (now 26), and the speed. If you want, grab the temps too. With the switch still active, simply select one more degree (now “2”), let it stabilize, record, and repeat in 1 degree increments until you see the speed peak, then decline. The total advance setting that corresponds to peak speed is now your target for your yet to be built “final” advance curve. What this is doing is finding optimum engine output for that mixture, tailored to YOUR airframe, engine and prop combination. Once your final advance curve is built and you once again are cross country, high and ROP, you can use the same technique to find your “LOP” setting. The only difference is that you will now be at a RPM and MP derived “optimum” advance (let’s say it’s 31 degrees) with the LOP switch INACTIVE. You will pull the mixture to your typical LOP setting, the speed will sag a bit (as usual) and the FF will plummet. Once again, select the LOP window on each CPI and input 1 degree advance. Record your (stabilized) speed and then activate the LOP switch. You will see a bit of the speed come back shortly, so as before, add advance and find the peak speed. The optimum advance setting you find is now your “permanent” LOP switch setting. In my case, my Rocket regains 3 knots with the flip of that switch when LOP.
That’s all I have for now. If I (or anyone else) thinks of any more they should drop it here. CPI is one of the newest ignition products on the block so the pool of knowledge is not as deep as others. Hopefully, this thread will serve as a resource for current and future CPI cusomers.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
Old 03-23-2017, 01:39 PM
tim2542 tim2542 is offline
Default Another happy customer
I made the mistake of switching the control box via my "mag" switch instead of the coils. Obviously if you want to read the tachometer while testing the other ign system you need the control box running. A simple oversight but it required me to re-wire the system.
The other thing I ran into is the color dye on the tiny magnets is easily removed, so just be careful when handling them you don't wipe it off. It's easy to sort out if you do remove it but requires additional head scratching.
I curious why the instructions advise not to use a timing light with built in advance. That's the only type I own and it worked just fine.
Tim Andres
Old 03-23-2017, 03:06 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Tim Andres
Some knob type timing lights don't read correctly when used with waste spark type systems since sparks are happening at double the "normal" frequency.
Best to use a cheap, dumb Walmart special.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 457.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 10-13-2017, 07:56 PM
rv6ejguy's Avatar
Default CPI Self-Test Spark Feature
I thought I'd shoot this short vid today while I was testing some new coil modules. Some people might find this helpful if troubleshooting:
https://www.youtube.com/watch?v=SAooHa0PhdA
Old 10-14-2017, 05:36 AM
maus92 maus92 is offline
I would love to see a video of the timing light in action - I'm still a bit confused about the process on an airplane with an engine running and a spinning prop..
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 10-14-2017, 10:05 PM
gasman gasman is offline
I agree. I find it hard to picture how you can time within 1 deg. with the timing light flashing on two lines that are only 1/8th thick leaning over a running motor standing 30 inches from a spinning prop and trying to view straight on over 24 inches away...........
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 10-14-2017, 11:45 PM
Toobuilder's Avatar
The same way you did it on your Camaro or Mustang back in high school auto shop. Aim the light at the marks and when it lines up, you're done.
Michael Robinson
______________
1984 L39C - SOLD
Old 10-15-2017, 03:51 AM
Larry DeCamp Larry DeCamp is offline
Default Mount the timing light
For the faint of heart ( me included), mount the timing light like a prop balance sensor on the case and use your cell phone to video the timing mark. You only need to do it once.
Larry DeCamp
RV3B sold
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 10-15-2017, 08:09 AM
I wasn't aware that Camaros or Mustang had props - I must have missed that class (We actually didn't have an auto shop at my high school.)
The suggestion about mounting the timing light similar to a prop balancer, then using a cell phone camera (I might use a GoPro) seems like a safer procedure.
CA
Old 10-15-2017, 08:39 AM
rv6ejguy's Avatar
I've taped the gun to the top of the engine and put an elastic around the trigger. An overcast day works best and I usually also put a strip of white or silver tape on the flywheel to reflect better.
On our Continental, I also built a sheet metal tab to project the case split line closer to the prop hub.
We'll hopefully be running a test 360 soon. I'll shoot a video then.
I like the smart phone idea though too.
Maybe binoculars if your eyes aren't as good as they used to be?
