Old 01-19-2022, 11:27 PM
greghughespdx's Avatar
Default SkyView 16.2.4 software and RV-12 settings packages published
We’ve published the SkyView 16.2.4 software with the RV-12 settings files to the Van’s Aircraft web site downloads page, as well as the README file describing the steps to install/update.
We revamped the way we package the software and settings. Previously all in one ZIP file, we are now publishing separate files for aircraft and engine combinations:
  • RV-12iS with Rotax 912 iS Sport engine
  • RV-12iS with Rotax 912 ULS engine
  • Original RV-12 with Rotax 912 ULS engine
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 01-20-2022, 04:11 AM
amekler amekler is offline
just downloaded the original 12 file and there are 3 12is files in it
Alan
N603NH
Old 01-20-2022, 11:58 AM
JwWright57 JwWright57 is offline
Greg - doing this update isn't going to mess up my fuel calibration is it? Or the trim settings?
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2022
Old 01-20-2022, 12:02 PM
Alan
N603NH
The ZIP files have been updated.
Old 01-20-2022, 12:34 PM
The only items modified in this particular update are the Dynon software and sensor files. The RV-12/12iS specific config files were not updated.
If you load a standard config file from the ZIP file over your custom settings established on your EFIS, your system will be updated to the default values. As described in the README file, each config file covers a certain category of settings in a fairly granular scope.
As also described in the README file, you only need to load the Van's .DFG config files if they have changed since the version you are currently running on your SkyView system. The README includes this instruction to provide a method to evaluate whether or not a specific config file has changed or not: "Enter into the aircraft logbook the filenames (which include dates) of the .dfg files loaded. In the future this may be used to determine if any .dfg files need to be updated by comparing the version of the files listed in the logbook to the file versions available on the Van’s Aircraft Web Site."
So, to be clear: If you were to load an RV-12/12iS specific .DFG config files, your settings will be reset to the configuration defaults for each configuration category loaded. Refer to the flowchart on p.3 of the README file, where you will see the notation, "Install Van's Aircraft .dfg Files (if changed)."
If all you load is the Dynon files per steps 1-9 in the readme, none of your airframe-specific configuration values should be changed.
Old 01-20-2022, 02:58 PM
Lucmac Lucmac is offline
What did the update address? Any new capability?
Old 01-20-2022, 03:00 PM
https://dynonavionics.com/skyview-software-updates.php
Old 01-20-2022, 03:01 PM
Bob Y Bob Y is offline
Dynon 16.4.2
https://preflight.dynonavionics.com/...n-162-now.html
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
