Keep VAF
Going
12-27-2021, 10:17 AM
Originally Posted by DanH
No big deal...you're a young man. More than a few guys here have quit buying green bananas.
Nice!
I'll tell you what, as a 56yr old stuntman, "YMMV" is very germane...
HAHA
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
01-09-2022, 12:39 PM
Jugs removed, hopefully, will find replacements...
[IMG] Amotor6 by Kent Luttrell, on Flickr[/IMG]
Piston pins seem to want to stay firmly where they currently live...hmm
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
01-10-2022, 05:18 AM
Do you wet torque all of your stud threads or just the through bolts on reassembly?
01-10-2022, 05:23 AM
Originally Posted by Dan 57
Thanks Paul, most probably is. Was just thinking too much
And it also shows how difficult a photo only analysis is... no depth perception, glare, etc.
Do you wet torque all of your stud threads or just the through bolts on reassembly as a wet torque?
01-10-2022, 10:58 AM
That is outside my scope of work. The case will go to Divco for recutting the mount and inspection, honing. The balance of parts to Aircraft Specialties and hope to get the parts back within a year...?
I will have it reassembled by a professional. But getting it apart without damage is in my wheelhouse...haha
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
01-20-2022, 12:28 PM
So the rod bearings are a mess, it's a good thing I took this motor all the way down.
[IMG] 20220112_134933 by Kent Luttrell, on Flickr[/IMG]
[IMG] 20220112_134936 by Kent Luttrell, on Flickr[/IMG]
I thought I had all the rods photo'd but clearly not. Only one was clean and unscarred.
Crank didn't look near as bad as the bearings but it will need some attention for sure.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Reason: incorrect ID of part
01-21-2022, 05:36 AM
I can't help but wonder if Barrett will do the rebuild... after all, they share the same driveway with Aircraft Specialties. Hoping that's the case, no pun intended.
01-21-2022, 05:42 AM
So the crank bearings are a mess, it's a good thing I took this motor all the way down.
Only rod bearings shown not mains. . ..
It looks like a main bearing spit debris (what do they look like?) into the oil stream and to the rod bearings. The main concern for the crank is wear.
Agree you are fortunate (very) to have taken this all the way down. The harsh scaring would have lead to catastrophic failure and likely throwing a rod. Now the oil cooler has to be replaced/rebuilt.  It started somewhere, better follow it to a source and understand it.
Maybe it's just me, but I like reading the story an engine presents when dissembled. Like reading a book with lots of threads and events. Oil, bearings, piston/ring/barrel wear, colors, gear contact and more. All the weaknesses and history revealed.
Bill
RV-7
01-21-2022, 05:51 AM
Same here - unfortunately sometimes the story does not have a nice ending, but we can certainly learn from it.
http://www.kathrynsreport.com/2019/0...14t-fatal.html
01-21-2022, 09:36 AM
I need to go back and re-shrink those pics, somehow they didn't take my resizing...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
