Old 01-14-2022, 09:38 AM
Walt's Avatar
Walt Walt is offline
I'd be interested in one of those Surefly's, I asked Jason at Osh last year if I could get a SF with a max advance of 28 for my HC 370 but the answer was basically nope.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 01-14-2022, 10:22 AM
pecanflyboy pecanflyboy is offline
Originally Posted by Scott Hersha View Post
Dan,
I just talked to Bruce about his engine. He said that he spoke with a Lycoming engine rep at Sun N Fun and was told that the max advance on the 390 with variable timing is 28*.
Incidentally, he has installed the SDS dual ignition system in it’s place, not the EFII system as I said earlier.
Attachment 20973
SPK. ADV. 20VAR - bottom row on data plate.
FALSE! The Lycoming EIS is fixed at base timing, configured by Lycoming...PERIOD. It is NOT advanced. If your Lycoming unit (Black) is advancing and not fixed, it has been tampered with. Therefore, there is no difference in unit behavior between a Lycoming EIS and a Surefly SIM in fixed timing.
Install the unit per the installation instructions it will work fine. Before you go off the reservation based on opinions on this thread, call Surefly. If it is a Lycoming EIS, call Lycoming.
Jimmy
Old 01-14-2022, 11:45 AM
DanH's Avatar
DanH DanH is offline
Jimmy, perhaps you might download Lycoming SI-1443R.
This issue is not that a variable timing EIS is available for the 390-D, but rather, how much is advance it allows. Way back when announced, the Lycoming folks refused to disclose the advance values...which is why Scott's posts are interesting. Several of us here, flying ignitions with the capability to switch inflight, determined the 28 ballpark to be the sweet spot for the 390 running LOP.
I'll attempt to confirm independently of course. And yes, the data plate says the subject engine was an -EXP, not D, not that it matters at the practical level.
Click image for larger version
ID:	20986  Click image for larger version
Name:	ScreenHunter_1023 Jan. 14 12.04.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-14-2022, 01:28 PM
Scott Hersha Scott Hersha is offline
Walt,
I’ll ask Bruce to contact you. He was going to sell me the impulse SF for $1400. This includes the drive gear and the ignition harness, which sell for $400+ each at Spruce. They have 1 hour of run time on them by Lycoming before shipping the engine. If you want both he has the other non-impulse one too. Be advised, you won’t have a warranty
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 01-14-2022, 02:54 PM
sailvi767 sailvi767 is offline
A bit unrelated to where the thread is going but I had issues with the Surefly install. Surefly went above and beyond to assist me!
RV-6 sold
F-1 Rocket
