Any A&P in/near Paine Field available to perform an annual?
tass
Active Member
My annual is due this month, and the A&P who did it last year is unavailable.
I'm doing most of the maintenance myself except a few things that I won't be able to:
* Compression check. I don't have the equipment.
* Propeller grease. Aeroshell 5/6 is on backorder (I've had aeroshell 6 on order since the last annual)
* Crack A/D. I have a scope, but not confident that I can identify this myself; I'm very willing to learn.
* I'm able to test the ELT, but not sure that's something I'm allowed to sign off on. It is, however, easy to access.
* Sign off the logbook - I'm not the builder.
Is anyone available to help? The plane is hangared at Paine Field, but am willing to fly and meet somewhere if it's this month.
Late reply, I know.
Vertex Aviation had availability at KBVS, so got it all done there.
Thanks for the suggestions!
You're welcome. If you feel comfortable doing so, would you mind dropping me a PM with your thoughts on how they were with your RV, and how they were to work with in general? Thx!
