Keep VAF
Going
05-17-2022, 05:08 PM
Oil Temp Thermocouple Fault - reading high?
I'll fess up, I'm a EEng, and I'm not sure how this could happen, but maybe someone here knows.
Is it possible for a thermocouple sensor to fail / intermittent in a way where it reads HIGH? I know a thermocouple produces a tiny voltage, and so the typical failure mode is an open, and it should read low. Or it shorts to ground, I'd expect the same.
Scenario was - older JPI monitor. Oil Temp reads sometimes absurdly high - like over 400F. Obviously not possible without smoking the oil, and the oil has no burnt smell. Yes plane is currently grounded. JPI uses thermocouples for all temp sensing.
the EGT/CHT is all reading normally.
RV6A in phase 2 as of April 2016
Donation made Oct 2021
05-18-2022, 05:20 PM
When my VDO oil temperature probe was failing, it spiked high into the very high 200 degrees, then read erratic for about 30 seconds to a few minutes, and then would stabilize. It was obvious that the sensor was bad since it would be virtually impossible for the temperature of the oil to change that rapidly.
05-22-2022, 01:36 PM
I'm pretty sure the VDO probes aren't thermocouples.
05-22-2022, 02:31 PM
Tried the old test in boiling water trick?
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
05-22-2022, 11:58 PM
I've worked around thermocouples in aero research my whole career, and I never saw an occasion where a TC would fail high. But the JPI engine monitor on our C-182B had a bad EGT probe last year and it failed high, and intermittent for awhile. I can not explain it. But replacing the probe restored proper readings.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
05-23-2022, 06:23 PM
Very interesting Steve, thanks for sharing.
05-24-2022, 10:50 AM
Agreed. I believe it is a thermister potted into a brass housing. I made my own and this is how I did it. Just matched the thermister with the VDO characteristics. Thermocouples produce a micro voltage and thermisters provide a variable resistance. Very different. Thermocouples require special, polarity sensitive wire matched to the thermocouple type, therefore easy to spot.
Thread Tools |
Display Modes |
