Real talk: compressor size
spacedoc
Member
I'm awaiting my RV-14A tail kit and doing some finishing touches on my workspace. It's time to get a compressor. I'd like to get one that can support priming and ideally also finish painting down the road (if I do paint myself, I'm likely to do it in sections before final assembly, so I don't need a system that will support spraying the entire plane). I'm planning on using Stewart Systems (either EcoPrime or EcoPoxy).
Most literature online recommends a compressor with a 10+ SCFM capacity for spraying primer/paint. I don't have the infrastructure in my garage for a 220V compressor, so that caps me out around 5 or 6 SCFM based on the available compressors I've found. I'd like to hear some practical experiences from folks who have primed/painted with lower SCFM compressors. I understand that a lower SCFM rating means that the compressor might not be able to "keep up" with the gun, but if I can shoot smaller parts and not have to run the gun continuously for long periods, I figure that might be OK. I'm not sure whether there are issues other than capacity that might impact the quality of the application.
I'm looking at 20-25 gallon units and plan on running 3/8" hose to make sure I can get the flow rate I need to the gun.
Any comments/experiences are welcome! Thanks in advance.
I primed and finish painted my RV-6 (in pieces) with a conventional gun back in the day. In theory, that gun used a lot more air than today's guns. I used the same compressor to prime the RV-10 and paint the interior of the RV-10. I didn't have any air supply issues on either project.
It is a Sears 25 gallon, 1.5 HP compressor that advertises 7 SCFM at 90 PSI.
Probably a $300 compressor in today's world. Being single stage, it is loud, which I decided I could live with.
I have a compressor similar to Carl (previous post). It handles painting quite well, but not sure I'd want anything much smaller. It uses 17amps at 240v, so a lot of juice that you said you don't have.
What about just using a smaller compressor that runs on a standard 120v circuit for most of the build. Then when needing to spray paint, beg/borrrow/steal someone's similar compressor? Run them in parallel, each through regulators set to the same pressure to balance the air loads. Basically you'd be getting 25a and 120v, similar electrical power, but delivered differently.
Thanks, all. I think I’ll plan on priming with a 110v in the garage and then figure out what I’ll need to tackle painting once I get to that stage.
I bought a lower cost 'oiled' direct drive single phase thinking it would be quieter (wrong). I just traded up to a Husky 'Silent' Model. Its oil-less (scroll type?), but night and day difference and wish I would have bought one of these from the start. 5.0CFM at 40PSI.
Solution
If you have a small compressor the solution to volume is get a second tank for storage.
Now I have an 220 volt 80 gallon compressor with a 100 gallon storage tanks inline. Yes that's 180 gallons of air storage. Great system for anything
But that said in the past (Many years ago) I've used an 8 gallon compressor and put an old compressor tank inline for storage.
I bought my 100 gallon old compressor tank off Marketplace for $100.00
It helps the air cool down from the strain of the little compressor
Your luck may vary Art
Unless you want to hear the compressor screaming all the time, get a 2 stage low rpm compressor. My motor rpm is 1800 and I run my compressor much slower. It’s high CFM and it just thumps away. Almost as good as an old Lister. I have an Ingersoll type 30, but Kellogg also makes good compressors.
