Originally Posted by David Z
They seem pretty clear that we need a diversity antenna:
"The aircraft system will require an antenna able to broadcast out toward space-based ADS-B receivers emitting 1090 MHz Extended Squitter. This requirement can be met either through antenna diversity (the use of a top and bottom antenna) or with a single antenna that is capable of transmitting both towards the ground and up towards satellites. Bottom mount transponders alone are insufficient.".
I recall a post on VAF from someone involved with the satellite testing reporting they can receive adequate mode S signals from the lower mounted antennas but I can not locate it at this time. (Was in the last few years)
If a top and bottom is required, another option may be to mount an additional Transponder antenna on the top of the fuselage and use a 50 ohm 2 port power divider. This would allow the use of a standard mode S Transponder.
The coax from each antenna to the power divider would have to be the same electrical length to keep the antennas in phase.
I have constructed them for both 144 and 432 MHz and they perform well.
http://www.pnwvhfs.org/conference/20...r-dividers.pdf
