w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 09-26-2023, 11:12 AM
sahrens's Avatar
sahrens sahrens is offline
Default Trail?
Is the rudder actually in a straight trail position when the pedals are neutral? Watching the video it appears to nose up and slightly roll left as if the counter weight is not doing its job. As if the rudder was slightly off center to the left (left pedal applied.)
Can you feel movement in the rudder cables when the tail is wagging? Push the pedals forward so there is no slack in the cables and light touch one. Is there slight movement in the cable. How tight are your chains? Are the two chains the same length? How are the springs in your cables, they do wear out and after 750 hours in a year they could be worn out.
A solution could be a small strake mounted on the bottom of the fuselage under the elevator. A lot of aircraft use strakes to reduce tail wag / shuffle. I have no idea as to the size needed, but probably not very large.
Scott
Old 09-26-2023, 11:16 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is online now
Originally Posted by MacCool View Post
My RV-9A doesn't wag even a little bit, neither visually, reflected in the EFIS/instrumentation, nor seat-of-pants. I've experienced it in some larger airplanes ("Bonanza Boogie") but didn't know it occurs in RV's. Are yaw dampers much of a thing in RV's?
That's what I thought about mine, too, till I saw the video...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Old 09-26-2023, 11:25 AM
Bruce's Avatar
Bruce Bruce is offline
Default Aileron issues ??
I would check for slightly heavy left wing.
Check radius on ailerons
Hunting for level.
There is play in rigging somewhere.
Also check servos in wing.
My .05
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
RETIRED————————-Enjoying life
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2023 DUES PAID
Old 09-26-2023, 11:34 AM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is online now
Originally Posted by D-Dubya View Post
My RV-7 doesn't wag like that, either.
RV-7A here...same thing. Occasionally after getting smacked around by turbulence, but nowhere near that and it damps out quickly. During normal cruise, smooth as silk.
Something is out of whack somewhere on this one...
2022 Dues paid!
Old 09-26-2023, 11:37 AM
MacCool's Avatar
MacCool MacCool is online now
I too have seen the video, both from wingtip and tail tie-down, so...pretty confident, but next flight I'll try it making a concerted effort to keep feet off the rudder pedals.
RV-9A, 2011, IO-320D1A bought flying
Not a builder
Old 09-26-2023, 11:55 AM
birddog486 birddog486 is offline
It appears the rudder is straight in trail but I don't have a camera I can mount to confirm in flight.
In the video my feet were hard on both pedals. If I step on one side it stops the wag because of the slip but once centered or just left to trail freely the wag will start (in turbulence)
The tail wheel springs and chains are kept fairly loose, probably 1/2" slack which should have no effect on the control surface. Theres no springs on the rudder pedals or cables themselves.
Old 09-26-2023, 12:12 PM
sahrens's Avatar
I meant the springs at the tail wheel chains. If you are on the pedals there is no slack, so if the chains are different lengths you pull the rudder out of alignment. The aerodynamic force moves the rudder back to neutral but the chain spring pulls it slightly back out of alignment setting up the oscillation. It wouldn't take a lot of rudder deviation to get that much nose movement. But with 1/2" of slack in each chain it may not be the cause.
Just a thought
Scott
Old 09-26-2023, 09:52 PM
rmarshall234 rmarshall234 is offline
Somebody earlier mentioned the “ Bonanza Boogie “ and since I own a V-tail, I know it well. If your model-specific suggestions don’t pan out, I suggest a little research on this phenomenon which as I recall, is an inherent instability caused by the flat-bottom design of the fuselage. RVs are pretty flat on the bottom so maybe there’s a correlation. I must be compensating for it with rudder pressure because I don’t even notice it anymore but I don’t ride in the back seat. I put a GoPro on the tailring once and almost got sick watching the video!
Robert Marshall
RV-3 - 500hrs
A&P / IA
Parachute Rigger
Acroduster SA750 - finished and flying
Old 10-01-2023, 07:07 PM
No smoking gun yet but I do see the signature of turbulent air across the rudder after flying through some dirty water.
If someone can compare there Vertical and rudder I'd appreciate it.
My vertical stab is a consistent 1/8" wider than the leading edge of the rudder when in trail top to bottom and with very light pressure on the rudder pedals in flight I can feel it being pulled side to side.
Click image for larger version
Name:	rv rudder 1.jpg
ID:	48920  Click image for larger version
Name:	rv rudder 2.jpg
ID:	48921  Click image for larger version
Name:	rv rudder.jpg
Old 10-02-2023, 07:32 AM
N16KY N16KY is offline
Is the rudder counterbalance weight tight?
Nick
N16KY
RV7 slider with:
Titan IO370 with 9.6:1 compression, cold air sump, Pmags
Whirlwind 300 Series 3 blade 72" prop
Advanced Flight Systems IFR panel (I don't deserve it)
SuperTracks canopy extension mod,
AntiSplat "Almost a 14" seat mod (nice)
Flightlines Interior (nice)
Custom center console
Polished with minimally painted fiberglass fairings
EAA Builder's Log: https://eaabuilderslog.org/?s=N16KY
