w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 09-01-2023, 10:22 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Originally Posted by Bavafa View Post
A possible correction to the Garmin post, looks like th newest guide is rev Y.
Edit: I am curious what happens to the existing calibration. Is it retained and if so, is it retained with flaps down or flaps up.
Rev AU
https://static.garmin.com/pumac/190-01115-01_au.pdf
Brian Decker
EAA Technical Counselor
RV-7 (Flying)
Old 09-01-2023, 10:40 AM
Bavafa Bavafa is offline
Originally Posted by bjdecker View Post
Rev AU is for the installation and Y looks to be for the Guide.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 09-01-2023, 10:51 AM
mburch's Avatar
mburch mburch is offline
The installation manual makes it pretty clear that the second calibration curve is optional. Any AOA calibration you currently have will be used for both flaps-up and flaps-down conditions, unless you choose to revise your calibration.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
Any opinions expressed in this message are my own and not those of my employer.
Old 09-01-2023, 11:34 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GDU 4XX v9.31
Originally Posted by dmattmul View Post
Added support for second AOA calibration curve for flaps-down configuration
Justin, is this available with VPX controlling the flaps? I don’t think it can be but can you confirm?
Yes, the G3X Touch will use flap position as provided by the Vertical Power unit, to determine which calibration curve to reference.
Nothing will change relating to AOA calibration upon updating your system, an existing AOA calibration will be retained and flap position will have no effect on AOA indications. You will however have the option to perform a second calibration, if properly equipped. Once complete, flap position determines which calibration curve is referenced at any given point in the flight.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 09-01-2023, 12:24 PM
PilotjohnS PilotjohnS is offline
Default scenario
Justin
This is better than what i have now, but lets think this thru.
I calibrate one settings for flaps up, and I calibrate another setting for flaps down full. My flaps position goes thru the GEA24 and displays on my G3X.
If i am at partial flaps, which AoA curve is used?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
Flying June 2023
www.pilotjohnsrv9.blogspot.com
or builders log here on VAF: Pilotjohns
Old 09-01-2023, 12:45 PM
g3xpert's Avatar
If a flap position sensor is used, the system will reference the Flaps Down calibration curve anytime flaps are extended beyond the position corresponding to halfway between full flap extension and full flap retraction.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 09-01-2023, 01:45 PM
Justin
Thank you Justin, I believe I was not clear with my question and it was a dumb one to begin with. Somehow I thought if I go thru the calibration, maybe my existing one will be retained and be used as one of the setup.
Now, that I had coffee, I do understand that when I go thru the calibration, all will be new and will need to be setup for both flap up and down.
Mehrdad
Dues paid
Old 09-01-2023, 02:40 PM
dmattmul dmattmul is offline
Default Thanks and related question
[quote=g3xpert;1709511]Yes, the G3X Touch will use flap position as provided by the Vertical Power unit, to determine which calibration curve to reference.
That will help us Vertical Power users with AOA set-up flaps up and at least 50% flaps down calibration. Is there a way to use our flap and trim inputs from the Vertical Power system in the Advanced Guage Configuration set up? Without this Vertical Power users cannot use this feature since we can't set a logic signal to a flap or trim input or at least I have not found a way.
Old 09-01-2023, 03:49 PM
g3xpert's Avatar
Default Vertical Power EIS Data
We are glad to know our users are excited about the recent updates. We built this feature around the native G3X Touch EIS interface, which is of course a bit different from the serial VP-X EIS data stream, but I will raise the concept of incorporating VP-X derived data into the logic signal function with the team for consideration/feasibility, to see if we can work it into a future software update.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 09-01-2023, 04:47 PM
Justin
Thanks, the Advanced Guage System Garmin designed is truly cutting edge.
