Until I get it weighed were do I look for accurate weight and balance information, or about what should this thing weigh?
I bought a RV6A from an estate, it was a slow build kit, small tail, that first flew in 2003, it has a 430 and a nav/com, transponder, full gyro panel, autopilot with altitude hold so it is likely a little bit heavier than some, here is my information from the published sources that I have: AC log book entry EW 988.5, no gross weight published, POH #1 EW 1068, GW 1650, POH #2 EW 1189, GW 1750.
Both POHs have a photo of the airplane with the reference to the airplanes N number, is there somewhere else I can find weight and balance information, I have the blueprints but I do not have the builders logs.
Thank you for you help....
Jim Skinner
RV6A
RV 6 regrettably sold
Exempt, I donate each year because it is one of the best RV tools out there.
Jim Skinner
RV6A
