Go Back   VAF Forums > Education > Flight Testing
  #11
Old 07-05-2022, 08:48 AM
rocketman1988 rocketman1988 is offline
Default Öand
Climbing to those altitudes will likely prevent you from maintaining the recommended high power settings required for engine break inÖ
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
Old 07-05-2022, 09:36 AM
gyoung's Avatar
gyoung gyoung is offline
Originally Posted by Mel View Post
Typically you shouldn't venture beyond gliding distance from a runway on the first flight.
Granted. Perhaps I should have said starting with the first flight. The point is, you donít need any special tests just to land at a different airport, barring any restrictive conditions at the airport.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
Old 07-25-2022, 09:24 AM
agent4573 agent4573 is offline
My DAR told me the first takeoff and landing HAD to be at the same airport. I'll have to reread the Ops limits when the plane comes home from Osh to verify the wording. Basically he said that I can't land at another airport because I don't know what my take off / landing numbers are, so I can't legally meet the requirements of 91.103. After the first flight, you've demonstrated a single point for TOLD info, and can legally go land at any other airport in your test area.
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 07-25-2022, 09:45 AM
Mel's Avatar
Mel Mel is offline
Never heard of this interpretation. If you don't know the landing requirements for your aircraft, then why would another airport be any different?
P.S. Nothing in the op lims referencing this.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-26-2022, 10:25 AM
I think there's a lot of reasons one airport can be different than another. My first flight airport was a 6300x100 ft runway. That seems safer than taking off on a 6300 ft runway and attempting to land on an 1800x40 ft grass strip surrounded by trees. In my case the DAR just made the bad choice explicitly illegal until I had TOLD information.
Old 07-26-2022, 10:51 AM
Mel's Avatar
Mel Mel is offline
A DAR MAY add restrictions in the name of safety. I was simply stating that there is no rule that says the first take-off and landing must be at the same airport.
An example is that if I decided to do my first take-off from my 1500' X 20' strip, I would not be making my first landing here! Of course I have no intention of making my first take-off from here either.
