  #61
Old 07-02-2022, 04:47 PM
BillL's Avatar
BillL BillL is offline
Originally Posted by Northernliving View Post
Bill, this looks really nice! At what RPM will this start generating power? The B&C pad mount pics up around 900-1000 rpm. How does yours compare?
Originally Posted by monkworkz View Post
You'll get 15 amps at around 1000 RPM, over 1800 you get 30 amps.
Bill
Are these engine or alternator/generator RPM?
Bill
RV-7
Old 07-02-2022, 06:21 PM
monkworkz monkworkz is offline
Both are crank RPM, so around 1000 RPM crank RPM you'll get 15 amps, 1800 crank RPM you'll get 30 amps.
Bill
Monkworkz.com
Old 07-16-2022, 06:16 PM
Chkaharyer99 Chkaharyer99 is offline
Bill,
Will you be at Osh 2022 with a sample of the Monkworkz Generator?
Charlie
RV-8
Old 07-16-2022, 06:32 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
I can report the Monkworkz generator on my RV-8 works perfectly.
Carl
Old 07-16-2022, 06:39 PM
johnbright's Avatar
johnbright johnbright is offline
Default Monkworkz at Oshkosh 2022 thread
https://vansairforce.net/community/s...d.php?t=207613
John Bright, RV-6A, N1921R, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 07-16-2022, 10:00 PM
Originally Posted by johnbright View Post
Thank you John
Charlie
RV-8
Old 07-17-2022, 10:35 AM
azonic75 azonic75 is offline
Default Works great
Just finished the install. Instructions are excellent and it does exactly what it is supposed to so. Support has also been excellent. Quite happy to replace my SD-8 with this.
RV-8a Flying
RV-10 Building
J-5A Flying
Extra 300 flying
Old 07-17-2022, 12:14 PM
Originally Posted by Chkaharyer99 View Post
Bill,
Hi,
Yes, I'll bring one along for people to check out.
Bill
Bill
Monkworkz.com
Old 07-20-2022, 12:25 PM
NORDO Industries LLC NORDO Industries LLC is offline
Hi Jesse,
Yes, I am working on a belt driven version. There are some mechanical hurdles so don't expect anything for quite some time but it is my intention to make one that runs on the front of the engine.
Bill
Doubling down on the request for this from us RV-12 people who live in a perpetually weight-constrained world.
The output of the standard Rotax 912 ULS electrical system is limited at 15 amps, so a backup with significantly more power would be incredible.
An even better solution would be a mount which interfaces with the currently-empty vacuum pump mount on the back of the gearbox, since this would avoid having to modify the cowling to accommodate the belt drive. On the RV-12, this would need to take into account the pitot connection block, but that can probably be solved with a unified bracket which combines both functions.
Old 07-24-2022, 11:58 AM
Thanks for the reminder, this is for sure something I'd like to tackle. I'll send you a message.
Bill
Bill
Monkworkz.com
