Quick survey please...more research.
Subject is oil filter diameter. Specific interest is the max possible OD when mounted on a filter adapter calling for a xx108 or xx109 series filter.
Not an all-inclusive list, but examples might be the angle adapters from Titan, B&C, and Superior.
A standard Lycoming AC-style points the filter straight aft, has a built-in element bypass, and use a 110/111 filter. Not of interest here.
Please check clearances in the vicinity of the filter base, motor mount, rear alternator, etc, and tell me what you have. Standard Champion/Tempest is 3.7". Do we have 4.3"?
