Bowden Cable Boots
Kyle Boatright
Other than using the trial and error method on Ebay, is there a source for the rubber boots that seal the ends of Bowden cables? I need to replace a couple of them on throttle and trim cables and I'm not having success locating boots that I know will fit.
Aircraft spruce has them.
search "ACS grommet"
They have several different sizes that should do the trick....
Phil
RV10 built/flying
Bountiful, UT
