Any tricks for drawing a canter line down a length of J channel?
RV-Ogler
Active Member
Any tricks for drawing a center line down a length of J channel?
The plans say to draw a center line down a 6’ length of J channel. I’m trying to imagine a tool I could make that would allow me to make this quick and easy. Anyone here have any ideas?
Hinge
Use a small piece of hinge. Use one side, drill hole for sharpie correct distance from knuckles. Hook knuckles on edge of channel, insert sharpie, slide hinge along edge of channel. Perfect line every time…
Simple method
I use a small carpenters square that has an adjustable rule to mark a series of dots the required distance from the edge and then join them up with a 24 inch straight edge. Takes less than a minute to do.
Previously tried more complex setups that needed three hands to work but found that simple works best, for me.
You could also eyeball the center, use your finger along the edge to brace your ultra fine marker, and drag the edge. It’s very accurate and fast.
Carpenters square
Used this tool often.
I made this about 30 years ago when working on the 4 from stuff I had on hand. Fits the fine point Sharpie. The square tube is hollow. Crude, by amazingly effective.
I use it all…the… time.
Use a caliper to set the edge distance and run it down the edge.
I ended up using a scrap piece of J channel. Then located the hole by laying it over the actual J channel and center punching the scrap through where the plans had me drill a hole on the 6’ length. Then drilled a 1/16” hole on the scrap.
Slide the scrap J channel along the work piece w a fine tip sharpie in the 1/16” hole
Like this Idea
Alright, Seth, we're gonna try this one. Thanks for posting!
Mike
