Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-30-2022, 06:41 AM
Originally Posted by g3xpert
We shifted the IGRF database update to the navigation database, rather than system software based. This will make it easier for many aircraft to update that database when the time comes.
As a result of this change, if your navigation database is several years out of date when the v9.12 software is loaded you will see the IGRF invalid message. This means your Navigation database is many years out of date. A quick database update is all that is needed to resolve this message.
Fortunately we have been working on a free VFR database package for EAB installations! This will allow you to keep the basic databases in the system up to date at no charge. Brad will follow up on this soon here on VAF to provide more information on how to start making use of this.
Justin
That sounds great news re the free VFR Database Justin, will it be a global thing? Us in the UK and Europe would be very much happier if it was
Nige
Nigel Heald
RV9a G-CSAM @ Exeter EGTE UK
Finally finished
11-30-2022, 08:16 AM
I loaded 9.12, into my SLING yesterday. I monitored its progress in configuration mode and noticed it took a bit longer than usual to load/update my Com, G45R and G5. Will look to fly with it Friday, as weather is gonna be lousy today and tomorrow.
11-30-2022, 08:36 AM
Upload
After being a little intimidated from a software update last year I was concerned (terrified) that this one would not go as planned. Worked perfectly !!! Thanks Garmin. !!
RV-14A QB builds (2017), Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Earth-X batteries, Beringer wheels and brakes, Parts became real airplane 8/15/2020. Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade HRT 378, Earth-X batteries, Beringer wheels and brakes, real airplane hopefully early-mid 2024. Paid subscriber
11-30-2022, 08:42 AM
Justin
Great news. I am in that years old DB camp, as I use Foreflight for charts and the 430W for nav. Just don't want to spend $$ on another DB. Will this free DB include obstacle data in addition to the IGRF data?
Larry
11-30-2022, 08:52 AM
Larry
Yes - the free database package will include Obstacles, Terrain, and US Airport Information. See post here.
B/R,
Brad
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
11-30-2022, 11:22 AM
Refresh my memory on which button to hold down to stay in config mode and monitor the software download progress?
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7, Lyc IO360
AUO
11-30-2022, 11:29 AM
MENU button...
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
11-30-2022, 11:34 AM
Add optional CAS reminder to check baro-setting when on the ground
For those interested the limits for this is approx. 140 ft to high and 80 ft to low. Nice add. (Not that I ever forgot to set the baro  )
11-30-2022, 07:34 PM
On a stand alone G5, I’m getting the IGRF error too. Do I have to load a database to the G5 now?
www.N1017H.com
Tim Huneycutt, Capt, NCANG
CRJ/PC-12 Pilot
N1017H RV-10 Flying 2019
EAA Lifetime Member 1106970
2022 VAF Dues Paid!
11-30-2022, 09:52 PM
G5 Update
My G5 took quite a while to read the update through the can bus while the PFD and MFD went fairly quickly. (Less than a few minutes each)
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
