VAF on Twitter:
@VansAirForceNet
  #91
Old 11-23-2022, 08:10 AM
Longez's Avatar
Longez Longez is offline
Post
Originally Posted by GatorsR1 View Post
Thanks to Longez Steve for the concise questions.
Yes, I followed Garmin Install Instructions. Executed the downloaded GTR200_350 app on the PC, Ran the Garmin Install wizard, selected the Drive the SD card was in and gupdate.gcx was written on the SD card.
I'm wondering now if maybe I didn't initially select FAT32 to format the card ?
Or maybe the card itself has issues?
Card is currently in the GTR200B at hangar, will retrieve tomorrow and retry formatting & download.
If that doesn't fix things, the new 4GB SanDisk card (<$10) should arrive this week and will try that.
Thanks again for everybody's help, interest & time.
Hi Bob,
Yes, it is a good idea to check out the card on your PC to make sure that it is not reporting errors.
Right click on the SD card drive letter in File Explorer, Select Properties, then Tools and execute the error checking tool on that page.
If I ever have an issue using an SD card, the first thing I do is run error checking with File Explorer.
Steve
Old 11-23-2022, 09:14 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default seated correctly?
The insertion of the uSD card is a little tricky -- there is a detent to overcome in the slot and it has a push-to-eject action....
I encountered difficulty performing the update on a friends RV-12 / GTR-200 because I couldn't get enough of my fat finger on the end of the card to push it all the way in.
I suggest using a pencil eraser or similarly sized tool to push the card in...
Brian Decker
RV-7 (Flying)
Old 11-23-2022, 01:29 PM
Longez's Avatar
Post
It is also important that the SD card be inserted correctly with the contacts up as shown in this picture.
Click image for larger version
Name:	Correct Way to Insert SD Card.png
If you force the card into the unit with the contacts down, the SD drive will likely be damaged.
I updated a second GTR 200 to V3.50 today with this 32 Gbyte card, and it again worked perfectly.
Steve
Old 11-28-2022, 04:30 PM
kovacjd kovacjd is offline
Default Softward finally updated
Follow-up on my Software update challenge. The 4GB card did the trick. It's now on V3.5.
I did double check my 32GB card for errors. There are no errors. For whatever reason, the GTR-200b never recognized that card.
Josh Kovac
Oviedo, FL
Jan Bussell Alumni
2007 RV-6A Sold
2021 RV-7 Flying (N98211)
Old 11-28-2022, 06:07 PM
GatorsR1's Avatar
GatorsR1 GatorsR1 is offline
Cool
New 4 GB card arrived today, just did the download via the wizard and will see what happens when load into the GTR tomorrow.
Based on other's comments on success above ... confidence is high
Bob Costello
RV12 dream machine #120764
Support VAF - if you read it, buy it!
Old 11-28-2022, 06:20 PM
bjdecker's Avatar
Default Moot point...
FWIW, the just released software update for the G3X Touch - version 9.12 - contains the GTR 200/B 3.50 update...finally...
Brian Decker
RV-7 (Flying)
Old 11-28-2022, 08:36 PM
msires msires is offline
That’s a common limitation, it’s best to use the smallest SD card/ USB stick needed for the job when dealing with proprietary equipment.
Old 11-30-2022, 05:53 PM
GatorsR1's Avatar
Default bingo
Software update success ... inserted the "loaded" 4 GB, powered up and the GTR screen stepped thru the process.
Some way or another the problem must have been with the previous micro SD card.
Bob Costello
Old 11-30-2022, 08:07 PM
Glad to you got it sorted out!
Josh Kovac
Oviedo, FL
Jan Bussell Alumni
2007 RV-6A Sold
Old 12-15-2022, 06:32 PM
bjdecker's Avatar
Default Something changed...it's worse...
G3Xperts --
I loaded 3.5 into my GTR 200 (not B) and then flew this afternoon. In flight, 10 miles away from my home airport, the ATIS (118.60MHz) sounded like it was being received over another radio with background noise at the same time (the hiss of thermal energy of the noise floor); changing between SQ & RX made no difference.
I was running with 3.30 prior to today's flight without any issues.
I'd be happy to downgrade if you can provide an image/instructions.
I'll also send an email to G3Xpert.
Brian Decker
RV-7 (Flying)
