Tower cannot see my KT76A
dougmattson
Patron
I have been using this transponder for about three years when the tower now says they cannot see it. I have had it benched checked and the power adjusted to 200 watts. It outputted all the mode a codes on the bench along with a couple of mode c codes. I have changed the antenna, the rf coax, and the short coax and rf connector on the tray. I have borrowed the neighbors kt76a and the tower still cannot see me. I had the avionics shop start a vfr transponder check and his power meter showed 100 watts out of the antenna on the plane. Before we could see why the power was down his meter quit. He thought even at 100 watts they should still see me within 10 miles. I have tried a different tower also. I have visually checked the power and encoder connector and it looks ok. I have not done anything with the encoder. The interrogation light flashes 3 times for every sweep with my transponder. Only once with the neighbors older model. He says he has never had any trouble with his. Anyone have any ideas?
occasionally
Sometimes I get complaints from controllers also. My 76A is at the bottom edge of my panel. I've found that if I reach under the panel and push the connector in while pushing on the face of the radio the problem is fixed. (Autopilot helps when doing this little operation. ) The interrogation light blinks even when atc is not receiving, but tends to blink more rapidly after the fix. Seems to happen most often after I've removed and reinstalled the transponder. It sometimes happens after a full power climb out. John
You may try to find another shop that has some better test equipment, there are a number of things that can cause this all of which can be determined with the proper equipment. 125W is the minimum to pass the xpdr test but in reality 100W will still give excellent range so low power is not the problem.
To add to what Walt said. Those older units that use cavity tubes for xmiting are sensitive to having their freq pulled due to the coax lengths. Checking output freq is as important as power out. Regs call for +/- 3 Mhz but I have seen less deviation cause problems like yours.
Can you swap the xpndr?
Since the KT-76A is a very commonly used xpndr, do you have a flying friend or colleague that you can swap the xpndr with.
Would be an easy check to see if it's the xpndr causing the problem.
Regards,
Bill
Was this with a separate testing antenna on a stand a foot or two away from the plane's antenna?
If so, you are radiating an RF signal, and the most obvious remaining error would be a small RF frequency shift as mentioned earlier.
Yes. But why did it not work when I put a different transponder in? The current setup worked for three years but could something in the rf transmission line cause this shift?
Yes a bad antenna or coax can pull the freq out of tolerance.
My money is on the transmission line, either coax or connector. Yes, bad coax or connectors can do funny things to cavity tubes. Ask your shop if they have a TDR, Time Domain Reflectometer, just a fancy name for a pulse generator and oscilloscope. Have them attach it to your coax and it will pinpoint if you have a problem and if so, where.
Thanks for the ideas and I will follow up on them. But all coax, connectors and antenna has been replaced.
Did you check the connector in the rack? Are you sure it is seating properly?
Since your friend's working transponder doesn't work in your rack, it must be something downstream of the transponder itself. It's not un-heard of for there to be bad crimps/shorts whatever in new connectors. Is this RG400 coax?
Did you check with another radar installation? Many years ago, Memphis approach used to tell a lot of us (traveling to/from OSH) that they were either not seeing mode C or getting invalid altitude returns. Other radar facilities had no issues with the same planes on the same flights.
Charlie
I have replaced the connector in the rack along with everything else in the rf line.
I have tried a different atc tower also.
Did you use the King transponder antenna connector? It is not the same as all the others. It has a special attenuator inside. Little metal C shape the goes around perpendicular to coax. C-----coax.
Jay
