Can I energize my starter without the flywheel installed to test?
lndwarrior
Starting to test my electrical system and wondering if I can power the starter to check the electrical function without the flywheel attached? Or can this damage it?
It's a Skytech starter.
TIA
Gary
Starter test
Should be fine. I wouldn't let it windup to high rpm. Skytec tech support is very helpful.
Don Broussard
RV 9 Rebuild in Progress
Be ready to disconnect the ground cable if you wiring is wrong or solenoid sticks for some reason. You might think about having a second person hold the start button (switch?) while you touch the ground to the battery for a second to confirm correct solenoid operation.
Killing the master should take care of this...
I often click the starter without the power wire connected to the starter to hear the solenoid click.
I do it this way as well, and check for voltage on the starter cable at the same time. I can be pretty sure the starter will spin once I connect it in that case.
NEVER MIND
Most of you will figure out from my last post what went wrong. The light came on for me just after I made my own comment about my test fuse .
Duh! Of course I blew my 7.5 amp fuse them I tried to run my starter current thru it!!! Apparently I got confused between the starter relay current and the full load of the starter current.
Well, that's why we're test the electrical system, right?
And, yes, I do feel a little foolish right now!
