VAF on Twitter:
@VansAirForceNet
Old 12-07-2022, 05:38 AM
Webb's Avatar
Webb Webb is offline
Default Best clear coat for panels
For those that used a clear coat over dry transfers, what clear coat do you recommend?
Webb Willmott
Jackson, MS
RV8 - Current Build
V35B - Flying
RV7A - N32WW (Sold)
Old 12-07-2022, 06:10 AM
carlrai's Avatar
carlrai carlrai is offline
Default Recently used this over dry transfers
Eastwood polyurethane matte, clearcoat.
3 Very light dust coats, 15 min between coats followed by two more medium wet coats.
Came out beautifully.
A bit spendy but worth it.
https://www.eastwood.com/eastwood-s-...tte-clear.html
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 12-07-2022, 09:40 AM
DanH's Avatar
DanH DanH is offline
PPG Shopline has held up well, about 12 years now.
Sprayed 3 or 4 coats, cured, block-sanded wet over the lettering with 400, one more cross coat.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-07-2022, 11:24 AM
cajunwings cajunwings is offline
I’m closing in on finishing the panel. Does PPG refer to it as Shopline Clear Coat?
Old 12-07-2022, 12:45 PM
DanH's Avatar
You're in luck...it was still in the paint cabinet:
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-07-2022, 08:47 PM
Majorpayne317641 Majorpayne317641 is offline
Rustoleum rattle can enamel matte clear coat. It turned out great.
