VAF on Twitter:
@VansAirForceNet
  #21
Old 09-26-2022, 02:24 PM
BH1166 BH1166 is offline
Dave I used the same spot for ball mount, works fine.
Butch
RV6A Purchased N72TX
Old 09-26-2022, 02:34 PM
dbier99 dbier99 is offline
Originally Posted by CATPart View Post
The other ball is on the frame shared with the spar, about 3 inches below the side rail. I have like a 4 or 5 inch RAM arm between the 2 balls. It works great.
Thanks for info - I'm trying to picture your set-up in my mind. Would love to see a pic if you have one handy.
Old 09-26-2022, 02:37 PM
Unhappy
That's good to hear! I just need to be careful when drilling the mounting holes because the headphone wires run through that area.
Or maybe I can find an amazingly strong double-sided adhesive to use instead of the screws.
Old 09-26-2022, 02:44 PM
I still use a nexus 7, and I double sticky taped a RAM ball directly to the back of it.
What brand sticky tape did you use? I may be able to use it to avoid drilling and screwing a ball mount to the framing.
Old 09-26-2022, 02:45 PM
CATPart CATPart is offline
I did not want to drill that area either. I made what I would call a C-clamp out of wood, but it doesn't actually squeeze the frame, it is just super close and it is actually double sticky taped to the frame. The ram ball is then mounted to the wood. It has been holding well there for 6 years now. I am looking for a pic.
Old 09-26-2022, 02:54 PM
RV6_flyer's Avatar
I use a RAM X-Mount in my RV-6 and also have a MyClip for use in other airplanes.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-26-2022, 03:10 PM
I can get a better pic eventually if you are interested. Never had an issue with it in this spot, never got in the way, and it is pretty close to my face.
edit...What brand sticky tape: Probably 3M, thin foam sticky on both sides, whatever the hardware store had.
https://vansairforce.net/community/a...1&d=1664222762
https://vansairforce.net/community/a...1&d=1664222899
Click image for larger version
ID:	31538  Click image for larger version
Old 09-26-2022, 03:47 PM
Thanks for the pics and mounting tape info!
