I thought it would be a good idea to change out the tires on my 9A since I last installed them in 2011 (11 years old) and unfortunately haven't flown enough in that time to wear them out.
There's some cracking on my nose tire, but the mains look pretty good. How long should Aircraft tires last? (hangered indoors, but in Texas heat)
These manuals don't seem to say you need to replace them simply due to age, and unless the cracking shows the cords, that's OK!
https://www.bridgestone.com/products/aircraft/candm/care_win05.html
https://aircraft.michelin.com/wp-content/uploads/sites/15/2021/05/CSM_RevF_June2021.pdf
https://www.goodyearaviation.com/resources/pdf/aviation-tire-care-2020.pdf
I was shocked to see the prices of Tires and tubes now.
$105 for a 5.00x5 and $65 for the tube (from Vans)
$49 for a 4.00x5 and $16 for the tube.
I found a post from 2011 mentioning a nosewheel for $21 for the tube for $10!
