Originally Posted by Steve Ashby
I think I am sold on the Deutsch connectors. Would either of these be a good connector kit to start?
Ordering a DTM kit might not be a bad idea. Each connector needs maie and female shells and pins plus the wedges and silicone plugs that secure and seal the pins once they're inserted in the shells. You'll get all those with the kit. I ordered piecemeal and wound up short a part or two on a few occasions.
Also, I have the Stein barrel pin crimper. Would that work, or is it worth it to get the Deutch crimper?
It's been a few years since I bought the crimper, but I'm reasonably sure that this is the one I purchased for larger (>20 ga) DT connector pins -
https://theelectricaldepot.com/deuts...reenlee-p-1033
You'll find it cheaper on Amazon -
https://www.amazon.com/Paladin-PA146.../dp/B0848FPFCW
For smaller (20-22 ga) DTM pins, I used my Daniels crimper with a dSub turret but you can find a cheaper tool at SteinAir -
https://www.steinair.com/product/4-way-indent-crimper/
Hope this helps -
Dave
Dave Setser
CFII/MEI, Consultant DER
EAA Technical Counselor/Flight Advisor
RV-7 N701ED Flying!
Nashua, NH (KASH) / Plymouth, NH (1P1)
