IO-540 intake lock washers 1/4" internal tooth lock washer?
AV8ER
Got a question for the brain trust:
The Lycoming washers are $1.75 a copy.
(I think these are the right ones)
https://www.aircraftspruce.com/catalog/eppages/lycomin07-13820-32_07-03410.php?clickkey=127493
A standard internal tooth cad plated washer from ACS is $0.03 a copy.
https://www.aircraftspruce.com/catalog/pnpages/AN936-A416.php
Is there a difference I am unaware of or is the only difference cost because of the Lycoming name being attached?
I am replacing the intake rubber tube and want to replace the washers when I disassemble.
reference material:
https://vansairforce.net/community/showthread.php?t=32035
reference material:
The difference is $1.72. Seriously, it is a lock washer. Not a lot special going on there. I just use hardware store star washers. I would trust the ACS stuff if you feel the need for aviation grade. I have had no issues with zinc coated washers. Don't seem to corrode any faster than cad plated washers. Absolutely no way I would spend $1.75 for a star washer. With bolts and nuts I use Mil spec stuff, even traditional washers. IMHO, there is not much special about a star washer, especially in a low torque application like this.
Agreed about the star washers, just wasn't sure there wasn't something I didn't know as I am humbled daily.
For anyone wanting to replace their intake gaskets and tubes on their IO-540 (or 360), these are the parts required. (2) washers, (1) gasket, and (1) tube per cylinder.
AM-JKLW4ez39p7NQRnvpso-l84_lfJ7ViCzjDOsuLrn5H4Hi7mC4tFwmjW2bCsKeLrZyJz5zF7L-kBy2Czc2bRjABfJwWZlWCWxzyCTCObd2FAkk9YM_iHBn-kKulbNCs5G9EM8u-qRqk68upgi-aVVhu1KtLw=w800-h446-
Vic wrote a recent article about the intake gaskets getting crusty after being in service for a decade and mine indeed were crusty.
Uk95IkXmgPonTESAW5cezVpTvy5xzipqpgeWGVUhnPFDHKKtoNvbesxPyo2RiaNfGuzY6ieW7whQUs_Nu2wA_UU1CWIxtWBtQmnv2hqoJi8Dk9jBjlEvtlHYvw4Q7efBJVQCvzPOS1UNgu6dLwYrsXGtm2wybXX5QeYPfSLfqFOfqHHR9OSBQsXO8pZMWi4RDm24rlBmNh3x0EMA5bLWqh1UNubKsic17NWYQkA46eIkMX7_Y5s2l3MgZ-91laoCpmHLFpju-Li5jvb1ShsoChIlAwUhEwtofJXBgJV8fC0o5N-9aOCG11LpzD1rcvQauV5PRrmskf6b3tYcRqxnsFgURfSCW35xxMckfgdV3D5TJ-8DiQMLlTHhhMsIQcfZwLSj-1Usihjy00vK59rr0Zmf_wPiid0gW9sBHQWTlZsRNPXSsf1EaHbz0hMXP0lUWxsBCTyVf0WhxPrGF23m1I84twWw22RKskLNeAApg6xjVcUX6avvrnhPWfJOEUKM-sckPllxwFqTSo8MjHMqDn0oOqgUkam3-ZEBWWQz42AO8b4VDL5lGWLaRQS_0FkNIkseP70goU8JsUQ80Y0tbXN7hdOwZ99tjPagLtEuhxqZWAgaY5RRcAdtX78QmnN6_KTXYBAF0wjLXPBJqQjGZaY1VhU4j2cwK0arev8Hb2nq94OIJdasabUq4oIE6Fg1nedgeTBiew5Six_bvoAAZUpgDhvqXlPMLvHG99sp-DEcvSOnBNMn2xeDfE7ZEtqZfXeMNxp4DUOJARW5Y1nOV4cwv7ADrDNBS2xazHdB4d0MLMLAfll8nMbUzH7c_ed-ZK1rCdnx=w800-h731
I would argue with your bill of material for "parts required". The true solution is the SDS "no leak" O ring conversion kit.
Quit screwing around with tractor parts and step into the modern age once and for all.
