Help finding these in the plans
Chipper G
Working on my QB and I am trying to figure out when to rivet these open holes. I know the two small holes are for the fuel tank attach bracket but I can’t seam to find the rivet callout for the bigger holes or when I should rivet them. Any help would be appreciated TIA
I think they are countersunk bolts?
I believe those are for countersunk screws. You can refer to the skin drawings for fastener callouts.
You have the correct drawing and it identifies two different length screws to use for those holes. Looks like one bottom row hole should have a 1/8 in rivet installed.
Thanks all. Any idea when they should be installed? I can’t seam to find it. I think they can go in now.
When to install
I installed those fasteners after I did final mounting of the landing gear, and when I had a helper to assist me!
I installed all the remaining fasteners in that area after the bottom forward skins were riveted.
They install in the forward bottom skin section page 8-40. It looks like you can install them now.
