G3X Touch Manual Fuel Used Reset
iamtheari
I have a G3X Touch (software 9.00) with FT-60 fuel flow transducer and it all works fine. But I don't like that it automatically resets the fuel used counter each time I turn it on. Other posts here indicate that this is a setting that can easily be changed. But I can't find it.
In configuration mode, I go to the Engine & Airframe option and choose the FT-60, then I tap the button to bring up the Calibrate Fuel Flow page. This is where I think the auto/manual setting is supposed to be, but I don't have it. Mine has:
Pulses Per Gallon (K-Factor)
Full Fuel
Partial Fuel 1
Partial Fuel 2
Fill Threshold
There is nothing else here. The G3X Touch installation manual, revision AP, shows a Fuel Used Reset option after Partial Fuel 2 and above the Fill Threshold.
What preconditions are there for the Fuel Used Reset option to appear, which I could possibly be missing?
