Old 04-25-2022, 04:46 PM
wirejock's Avatar
wirejock wirejock is offline
Default Carbon Fiber
Short version... The Air Bits plenum gel coat was chipping. It's all gone. Belt sander! I hate gel coat.
Since it's rough, I'm considering a layer of carbon fiber.
How do I get that beautiful glossy carbon fiber?
Is that urethane clear coat?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 04-25-2022, 05:05 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Don’t use Peel Ply. Error on the side of more epoxy.
Carl
Old 04-25-2022, 05:25 PM
thiggins thiggins is offline
No expert here at all, but if you watch some of Mike Patey’s carbon fiber YouTube videos, he does use clear coat very often for that purty finish. Darned amazing skills he has there.
https://youtu.be/tqGnlFYAq1I
https://youtu.be/IycGsGzD16k
Donation 2022 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Empennage complete, Wings complete!, Fuselage under way !, finish kit ordered, Garmin avionics ordered, engine order waiting for the global economy to be resuscitated...)
Old 04-25-2022, 09:48 PM
Taltruda Taltruda is online now
I played with carbon a little, I found if you flood it with epoxy, it looks awesome! Probably not the lightest way to achieve your results. Perhaps there’s a UV resistant clear you could spray on?
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 04-25-2022, 11:37 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Laying the part in a positive form with enough epoxy.
Made an instrument panel for an older French Jodel this way, and it turned out pretty good, though not the lightest.
- ain't the Destination, but the Journey -
www.aerofun.ch
Old 05-14-2022, 10:26 AM
1001001's Avatar
1001001 1001001 is offline
One of the things that Patey does, I think, to get such nice looking carbon fiber weave is to pre-impregnate the cloth with resin. He doesn't explicitly show this step, but he's always applying sheets of cloth that are already wet. You can sometimes see him cutting the sheet from a larger sheet of cloth sandwiched between layers of plastic sheet, which he cuts with a rolling style cutter, usually.
That way, he's not stretching the fabric all over trying to squeegee resin into it while it's lying out on a curved surface, which will probably cause weird stretching and bunching. I'm no expert either, but from what I've seen some composite people do, it's all pre-layed up on a flat surface, impregnated with resin, and between two sheets of plastic to make the resin spread evenly, and make sure the cloth is all filled with no bubbles before ever laying it up into the final shape.
Old 05-15-2022, 04:11 AM
penguin penguin is offline
Its all a matter of technique. Use larger pieces of cloth than needed, wet out to the edge and cut back to avoid fraying. If bonding on top use peel ply. If finished part use plastic, but it is difficult to get the plastic to sit down flat if the part has any compound curve. Otherwise clear coat is required = a lot of extra work. Do not approach composite work with a metal mind set. Use more cloth than needed and cut back when still wet. Most composite parts that are not moulded are ground with a sanding disc to reach final size.
Old 04-25-2022, 11:54 PM
Richard Connell Richard Connell is offline
One of the main challenges of getting this right is not distorting the weave while you fill it with (heavy) resin.
Two ways to deal with that, either try get hold of some carbon cloth with binder on one side, or brush a light coat of resin onto your surface and when it tacks off, lay your cloth down. As you progress to wetting it out it will now stay in place.
Once that layer has tacked, brush on another layer. Repeat until satisfied and then block it all flat. Clear coat if you like.
As Dan says, this won't be super light, but it'll look good.
Ive made a few bits this way.
Richard
RV7 VH-XRC Sold :-(
RV10 VH-XRK
Sydney, AUS
Old 04-26-2022, 08:26 AM
wirejock's Avatar
Default Epoxy clear
Interesting. There's no UV inside the cowl. Maybe the clear isn't needed. Has anyone used West 207 on carbon fiber? It's a slow hardener but designed to harden perfectly clear. I've made some table tops with it. Time for some testing.
https://www.aircraftspruce.com/catal...xy2_207-SC.php
Larry Larson
Estes Park, CO
Disclaimer
Old 04-26-2022, 09:07 AM
BH1166 BH1166 is offline
Built a plastic plane years ago. To create some carbon items i took clean, scratch free safety glass, did layups on it, it popped off the glass after curing. Smoooth and shiny! Used same epoxy as all other tasks…nothing special.
Butch
RV6A Purchased N72TX
