w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-18-2023, 12:16 PM
moespeeds moespeeds is offline
Push it back on, torque just the big nuts, and rotate the engine with lots of lube sprayed into the bore. Get it all loosened up and try again with the cyl at TDC.
Mine was also a pia to get off, turns out the rings were delaminated and packed with flaked moly. Made everything sticky.
I wouldn't go nuts rotating the engine with no torque on the through bolts.
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 09-18-2023, 12:20 PM
abuura abuura is offline
Originally Posted by rmarshall234 View Post
With the valves closed and bottom plug in, apply shop pressure to other spark plug hole? Just spitballing here…
That’s a good thought. I’ll try it. With piston at bottom center (prop won’t turn) I’ll start with 20psi on the differential side and work my way up carefully.
David Abrahamson
Warrenton, VA
ATP, CFI, DPE, Repairman x 2
RV7, N98DA, TMX-O360, CS, slider
2023 dues paid!
gasman gasman is online now
Originally Posted by RheinRivets View Post
If the air pressure gets high enough, the suddenly loosening cylinder might turn into a nice projectile. Might work but I would proceed with extreme caution.
If you were to go in this direction, it would work if the piston was at the bottom of the stroke and use hydraulic pressure = no projectile... full control.
I think the penetrating oil should work for you.
VAF #897 Warren Moretti
2023 =VAF= Dues PAID
Old 09-18-2023, 12:22 PM
I’m hoping it does. Lycoming support says using the thick end of a wood shim to rock against would be acceptable too.
David Abrahamson
Warrenton, VA
2023 dues paid!
Old 09-18-2023, 12:35 PM
Be careful here... 20 psi will apply over 400 pounds force.
If you are going to use air, start at O and work your way up to 5 psi.
If that doesn't work, then go hydraulic.
Old 09-18-2023, 02:48 PM
Sage advice. Wilco.
David Abrahamson
Warrenton, VA
2023 dues paid!
Old 09-18-2023, 04:46 PM
Taltruda Taltruda is offline
Go and climb into the cockpit and yell “clear prop” and start the engine.. it’ll come off..it might sound like Dreadnaught for a few seconds..
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 09-18-2023, 05:18 PM
PilotjohnS PilotjohnS is offline
Default fluid, not air
if you are going to try air pressure, I would fill the cylinder with fluid, like alcohol or something, to minimize the volume of air, and the resulting pop.
But remember, you are going to be applying force to something that is hanging up, like coked deposits or something, so that force is going to be exerted on something that hopefully, will be able to take it.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
Flying June 2023
www.pilotjohnsrv9.blogspot.com
or builders log here on VAF: Pilotjohns
Old 09-18-2023, 06:21 PM
climberrn's Avatar
climberrn climberrn is offline
Heard a funny story recently. Difficult, rusted cylinders on a radial. They would fill the cylinder with Oxygen/Acetylene and light it. Would get it right off, and occasionally hit the ceiling.
Please don't try this. Just thought you would get a laugh out of it.
Joel
N626JA RV-7A waiting for IO-390
Purchased and flying RV-6A Constant speed, 200+ HP
Old 09-18-2023, 09:19 PM
wcalvert's Avatar
wcalvert wcalvert is offline
Huh Huh ... Fire Fire Fire
Click image for larger version
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
- Been there, Donated 2023
