Old 06-22-2022, 10:52 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
As promised... I flew today to test oil temp with ground temp at 90F. Per post #24 I modified lower cowling to move oil cooler 1" forward of the muffler.
Today's Flight: 80 F OAT, 222 F Oil Temp, 50 PSIG Oil Pressure.
Looks like I'm good for summer ops in northern OH...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 790
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 06-22-2022, 11:22 AM
NinerBikes NinerBikes is offline
What was your IAS and your RPM and how long did you run it at that rpm and altitude?
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 06-22-2022, 01:09 PM
DBRuth DBRuth is offline
Default Oil temperature
Jim, I'm glad you got the oil temperature back in the normal ops zone. I was starting to think my old muffler was most of the problem. The temps you saw were very much what I had with that exhaust system. I didn't want to modify the cowl , for only a little temperature relief, so I replaced with the new (2016) setup. I flew over the weekend,with ground temps in the mid 90's and never got over 220*.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @380
Dues paid 2021
Old 06-22-2022, 03:23 PM
Piper J3's Avatar
115 KIAS
5500 RPM
45 Minutes Cruise @ 2500 MSL
Old 06-23-2022, 06:10 AM
bobg56 bobg56 is offline
I did a few things that lowered my oil temp, I sprayed mineral spirits through the cooling fins of my oil cooler then blew it dry, also the replacement of the oil return line with the TS Flight line version (banjo fitting). I'm in SC and have been flying 1500' agl 95f at 5400...oil temps between 219-222F...I used to see 230-235F...I'm not sure which had the greater effect, washing the oil cooler or the new oil line. I did re pitch my prop to 71.4 from 71.
Old 06-23-2022, 07:35 AM
rvbuilder2002's Avatar
An over pitched prop can definitely cause elevated oil temps.
I am doubtful that either of the other things had any influence on oil temp.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 06-23-2022, 10:08 AM
seagull seagull is online now
What is your airspeed @ 5400 RPM?
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 06-24-2022, 06:35 AM
About 110 KIAS @5400...replacing the oil return line created some needed space from the muffler, old line had about 1/8" clearance
Old 07-14-2022, 07:57 PM
dbenoit dbenoit is offline
Default oil cooler misalignment on lower cowling
I kept having high oil temps to on climb out. Discovered that the lower cowling had been reinstalled incorrectly. The oil cooler lower portion was not seated on the lower pins. Therefore, it was pushed backwards nearer to the muffler. Less airflow and much higher temps. Once the lower cowling was reinstalled correctly, that ended the excessive oil temps.
Old 07-15-2022, 02:11 PM
MartySantic's Avatar
MartySantic MartySantic is offline
A few of us modified the cowling and moved the oil cooler about an inch+ forward 8-10 years ago by modifying the cowl. It made a world of difference with hot OATs. I believe Van's changed the design in the later kits to increase the distance between the muffler and the oil cooler, finally acknowledging, this was the cause of high oil temperatures on climb during hot days (think they modified the exhaust pipes to move the muffler aft). Well done, Jim!!!
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
