VAF on Twitter:
@VansAirForceNet
Old 09-19-2022, 05:51 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default EarthX Battery mount mod
So like many of you I decided to use an EarthX Lithium battery as opposed to the standard NiCAD. This of course means modifying the battery tray in the RV-10. My first attempt (which was still successful, picture 1) was using aluminum angle riveted to hold down the battery without modifying the stock location.
After showing this to some guys at work, one offered to design a 3D printed battery tray for me. After some back and forth and a couple test runs we finally got it right and were able to print 2 pieces that together hold the EarthX perfectly in place with no modification to the existing battery tray. The plastic parts just slip into place. Should fit either the ETX680, ETX900, or ETX1200 as they are all the same size box
Not too bad for a side project. Amazing what 3D printers can do for experimental aviation.
ID:	31243  Click image for larger version
ID:	31244  Click image for larger version
ID:	31245  Click image for larger version
Jon
RV-14A Sold
RV-10 Empennage - Complete
Wings - Complete
Fuselage - On Order
Finish - On Order
Old 09-19-2022, 07:56 PM
ohlone ohlone is offline
Hey Jon, I'm guessing a high temperature filament was used, which kind was it ? Which 3D printer ?
Old 09-20-2022, 12:27 AM
rv8ch's Avatar
rv8ch rv8ch is online now
That turned out very nice, and probably a lot lighter than the original aluminum solution. I have a feeling we're going to see more and more clever uses of 3d printing like this one in the coming years.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 09-20-2022, 07:00 AM
atwoodm atwoodm is offline
Would you be willing to share the STL files?
Mark Atwood
RV14A - N416SL completed 8/18/20
RV10 - Waiting on Kits!
Old 09-20-2022, 08:57 AM
mulde35d's Avatar
Originally Posted by ohlone View Post
Hey Jon, I'm guessing a high temperature filament was used which kind was it ? Which 3D printer ?
He said it was a high temp filament (not that it should matter much in a cold tail section), but that is about all I know about it. I am on a work trip for the next couple days, but will gladly ask him when I get back to the office
Jon
RV-14A Sold
Wings - Complete
Fuselage - On Order
Finish - On Order
Old 09-21-2022, 06:50 AM
mulde35d's Avatar
So I have received a lot of requests for both the STL file and for printing them for builders. I am going to talk to my buddy at work in regards to what he would ask cost wise to print, package and ship them, but if your interested in one then feel free to PM me your email and I will gather together a list for him. He said it was about a 14 hour print, so it may take him a bit to print a few of them.
Jon
RV-14A Sold
Wings - Complete
Fuselage - On Order
Finish - On Order
Old 10-04-2022, 08:33 PM
Moresushi Moresushi is offline
Default EarthX Battery Mount Mod
Jon I wanted to thank you for the STL file on this mount mod. This was my first effort at 3D printing and I'm very pleased with the results. I had been trying to develop a printed design but your offset idea was what I was missing. I will need to make another slight mod because I am planning the vented battery. But this will just require a small cut on the back side of the mount. One of my Tech Counselors saw it today and was very impressed. Thanks again for the great idea!
Name:	Battery Bracket Left View.jpg
ID:	31877  Click image for larger version
Name:	Battery Bracket Back View.jpg
Bill
Spring, TX
EAA Chapter 302 Member
KCXO Conroe, Texas
RV-10: Under Construction
https://eaabuilderslog.org/?s=wcooper
Old 10-05-2022, 06:07 AM
dmattmul dmattmul is online now
Default Venting in the back
Using a vented battery for the rear location in the 10 never a bad idea but just FYI Earth X told me (verbal at EAA) that this was probably unnecessary since the 10 has enough airflow already going front to rear. It does make since given the small tubes can only pass a given volume of air. Just FYI, build as you feel needed. If anyone hears different from EarthX please let us know.
RV-14A QB builds (2017), Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Earth-X batteries, Beringer wheels and brakes, Parts became real airplane 8/15/2020. Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade HRT 378, Earth-X batteries, Beringer wheels and brakes, real airplane hopefully early-mid 2024. Paid subscriber
Old 10-05-2022, 12:45 PM
AviatorJ AviatorJ is offline
Looks clean. I did a custom bracket bit for my battery and have not had any issues.
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
