VAF on Twitter:
@VansAirForceNet
Old 09-05-2017, 09:20 AM
petehowell's Avatar
Default Slow Cranking with Skytech LS
This has all been covered before, but wanted to add my experience. 1865 hour RV-9A with O-320 started cranking slowly on our trip to chase the Great Eclipse. PC680 was 6 years old, so we replaced that, no real change.
Original firewall master and starter solenoids - OK they owe me nothing at this point - 'bout time to replace those and clean up all the wiring contacts.......no real change in starting, cranks slow, but always starts. Wife comments that I had better fix that.....
Trip up to Lake Superior for lunch, starter spins, but does not engage engine, but fires up on second try. Dim bulb goes off in dim guy's head that there is another solenoid on the starter that not only engages the flywheel, but also connects the motor to the BA current. It was all here for me to read, but now I got it.
The solenoid on the Skytec starter is off a 2005 Ford Crown Vic(thanks to VAF for that gem!) Picked one up ($20 on sale no less!) and did a 20 min install. She now engages and spins like a champ again.
My 1987 Suzuki Samurai Alternator and 2005 Crown Vic Solenoid are now best buddies on the front of my engine and have lifetime warranties!
tldr - Don't be like Pete, be smart. There are 3 solenoids, know about them all.....
Pete
Amateur Plane - RV-9A N789PH - 2600+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 09-08-2017, 03:37 PM
Malndi's Avatar
Malndi Malndi is offline
Default Solenoid part number?
Pete do you know if the solenoid is common to any other cars? I may need to do the same thing but we don't have the Ford Crown in Australia. Hoping the solenoid is generic.
Old 09-08-2017, 04:07 PM
RV6_flyer's Avatar
I am not Pete but I have stayed in a Holiday Inn Express.
This post has the part number needed.
Copy / Paste from above link.
"The part number: BWD S5613 stands for Borg Warner, part number S5613."
I would assume that your location "down under" would have the same part number. I find it hard to believe that Ford Motor Company would only use the same basic engine in only one vehicle.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-08-2017, 06:00 PM
catmandu's Avatar
catmandu catmandu is offline
The equivalent NAPA solenoid ECH ST421 lists these vehicles as applicable:
Ford Crown Victoria 2001 - 2005
Ford Marauder 2003 - 2004
Ford Mustang 2001 - 2001
Ford Truck E150 1/2 Ton Econoline - Van 2001 - 2001
Ford Truck E250 3/4 Ton Econoline - Van 2001 - 2001
Ford Truck Excursion 2000 - 2001
Ford Truck F150 1/2 Ton - Pickup 1995 - 1996
Ford Truck F150 1/2 Ton - Pickup 1999 - 2001
Ford Truck F250 3/4 Ton - Pickup 1995 - 1995
Ford Truck F250 3/4 Ton - Pickup 1999 - 1999
Ford Truck F250 Super Duty 3/4 Ton - Pickup 1999 - 2001
Ford Truck F350 Super Duty 1 Ton - Pickup 1999 - 2001
Ford Truck F53 1995 - 1996
Lincoln Town Car 1998 - 2001
Mercury Marauder 2003 - 2004
Mike C.
Sierra Nevada
RV-6A bought flying SOLD
Super-8 bought flying
Old 09-08-2017, 11:29 PM
Malndi's Avatar
Thanks for the responses but it appears I can't get the solenoid in Aus, may need to have one shipped in, but will do a little more research before commiting to that option.
Just BTW, for decades Ford Australia manufactured it's own unique cars and engines in this country and none of the cars Mike listed were sold here.
Old 09-09-2017, 02:36 AM
hohocc hohocc is offline
A quick search on Rockauto shows the 2005 Crown Vic starter solenoid is about $36US delivered to me across the Tasman, must be similar to Sydney.
Old 09-09-2017, 04:20 AM
Malndi's Avatar
Thank you Craig! Rockauto didn't appear in my google searches so I appreciate the suggestion. Same quote to have it delivered to Sydney which is a good deal so I have placed an order.
Old 07-31-2021, 09:12 PM
Steve Graham Steve Graham is offline
I've been struggling to understand the operation of these starters. Not having much luck finding any info on the actual design of the skytec starters.
To clarify my understanding can anyone confirm the following:
The skytecs do not have a spring-type Bendix drive that moves the pinon forward into the ring gear. They use an electromagnet and a fork to accomplish the same thing.
They also do NOT have a contactor as part of the same plunger on the pinon actuator that prevents the starter from spinning until the pinon is completely engaged with the ring gear.
If the pinon actuator was to fail you would still hear the starter spinning during starter engagement.
Old 08-01-2021, 06:23 AM
bjdecker's Avatar
bjdecker bjdecker is offline
They DO have a contact under the two large terminals at the back/top/end of the solenoid.
In the case of the XLT, PM/LS, HT versions, if the solenoid plunger (white or black nylon thing) were to fail and become disconnected from the see/saw/fork arrangement, you would hear the starter spin because the solenoid would close the contact and allow current to flow to the starter motor.
However, we've seen a different failure mode with these solenoids -- the plunger becomes stuck partway or binds during movement and the contacts remain open; all you hear is the "clunk" of the Starter Relay (not Starter Solenoid) when you turn the key/push the button...
Brian Decker
RV-7 (Flying)
Old 08-03-2021, 06:41 AM
Thanks very much Brian.
If the firewall mounted solenoid we replaced doesn't resolve the issue we know where to look.
I drilled out the rivets on the old relay and there was some pitting on the contacts but not what I would consider "excessive".
