Resurrecting this thread. After a number of months, I finally got around to setting up my squeezer with a base and regulator but ran into a problem. I bought my unit without yolks since I have a full assortment of them already that I use with my pneumatic squeezer. When I tried to fit my yolk to the new squeezer I found then holes were slightly misaligned.
I sent the unit back to the manufacturer and they said their yolks fit perfectly. However, they manufacture their own yolks so it makes sense that theirs would fit.
So a couple of questions:
1. When you bought your unit, did you also order yolks or did you have existing ones?
2. Did anybody else have this problem with their existing yolks not fitting the Numatx squeezer?
Art Jackson
RV-14A Kit#140433
Last section completed: OB Leading Edges
Scrapped: Rudder
Working on: Fuel Tanks
Wing Kit Ordered 21 June 2021, Arrived May 6 2022
Construction log - mykitlog.com/ajackson
Dues paid January 2023
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
