Old 12-31-2021, 05:27 PM
lipper03 lipper03 is offline
Default Started my build
Hey all, I got my extra parts for vert stab and rudder today, so started my build! Lot's of fun, though Van's looks to have sent the wrong vert stab skin, my ordered part number is correct, but I don't think they sent the correct part.
Brian
RV-14A
Build Started 12/31/21-
Section 6-8 complete 8/17/22
*Emp Ordered 9/27/21- Delivered 6/30/22
*QB Fuselage Ordered 11/3/21- Est 2Q23
*QB Wings Ordered 2/18/22- Est 3Q23
*YIO-390-EXP119 Engine Ordered 5/14/22- Est 2Q24
*Prop Ordered 5/20/22- Est March 23
*Finishing Kit ordered 6/25/22- Est Sept 23
https://eaabuilderslog.org/?s=RV14A2021
PA-28-236 N419SB
KIWS
VAF donation 2021/22
CAF Member
EAA Member
AOPA Member
Old 12-31-2021, 05:38 PM
wirejock's Avatar
wirejock wirejock is offline
Default Part #
Helps a lot if you post the plans part number and the part number Vans sent. A photo also helps. If memory serves, it has an RV7 VS.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 12-31-2021, 05:58 PM
Default part ordered
Ordered VS-801PP (Vertical Stabilizer Skin). What I got, well the the label was under gorilla tape, so don't know what it was labeled. But it's taller and not as deep as what I need, plus there are cut outs, looks like to roll an edge.
I looked at a few other vert stab skins to see if I could match it, but in my short search I didn't.
Brian
RV-14A
PA-28-236 N419SB
KIWS
CAF Member
EAA Member
AOPA Member
Old 01-01-2022, 08:43 AM
PhatRV PhatRV is offline
Mistakes do happen. Send a picture to Vans builder support and they will send out the correct part. It happens to everybody. On the plus side, you will probably get the keep the bad part and you can use it as extra scrap sheet metal for other stuff.
RV8 (N38PV): 90% completed (90% to go)
Short List for Hangar !
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 85% completed
Donation paid through 2022
Old 01-01-2022, 08:56 AM
Thanks, yes already did that. Not upset, easy mistake, without measuring and looking closely it can be missed, until you put it up against where it's supposed to fit. I'm sure they will take care of it, in the meantime working on section 7.
Brian
RV-14A
PA-28-236 N419SB
KIWS
CAF Member
EAA Member
AOPA Member
Old 01-01-2022, 10:51 PM
N546RV's Avatar
N546RV N546RV is offline
Interesting. Now I really want to know what that skin is for...
Edit: Oh, that's a rudder skin, probably R-801PP. Notice how there are a lot more chordwise rivet lines compared to the stab skeleton - those are for the stiffeners.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 01-02-2022, 07:11 AM
Yeah you are right, it's the R-801PP for the RV-8, that drawing looks like the part I got. And VS-801PP is close and my order had both VS and R parts, so easy to get a R-801PP instead of a VS-801PP.
Brian
RV-14A
PA-28-236 N419SB
KIWS
CAF Member
EAA Member
AOPA Member
