O-320-E2C Oil Pressure
Cth6
I wanted to solicit to see if anyone has crossed this bridge already with low oil pressure when temps are cooler.
O-320-E2C - Carbed / Mogas
Normal Oil Temps at cruise 170-180F
Normal Oil Pressure at cruise 70-80 PSI
Normal OAT above 80
P66 Victory 100, 31 Hours and 4 months since change. Good oil history.
340 SMOH
Burns 1QT per 10-12 Hrs
Tempest 48108 filter
This is my first year with this RV. The past two flights have been in colder weather (50-60 F). Yes Winter has made it to Florida.
With the oil cooler air shutter closed (no other changes to the RV), I can get the oil temps up to about 150-155F. EGT and CHTs are normal, maybe slightly lower.
The past two flights the oil pressure has built up to 60psi during run up and take off but then degrades to 45-50psi after 30 or 40 mins of flying at cruise. Pulling the power back to idle to land the oil pressure drops to 30-40 psi.
There are no leaks and oil burn has not changed.
I am used to oil pressure being high when the oil is colder. I am going to test the oil pressure with another gauge (I have the Vans OP sender) to rule out a bad sender. I am also going to check the vernatherm to see if it is stuck open/dirty. I can see the oil temp drop when I open the shutters so I know the cooler is passing oil even at 140F oil temp
If I don't see a change, my next step was to do an early oil change and cut the filter. I can reduce the airflow into the cowl, but I am not sure that will help.
Any thoughts on other areas to look at or test?
Thanks!
Chad
Try pulling the oil pressure relief valve ball and spring, and see if something is holding it open.
Have you considered using a multi-grade oil like "PHILLIPS 66 VICTORY AVIATION OIL 20W-50?"
https://www.aircraftspruce.com/catalog/eppages/phillips_08-17114.php
It seems to have some benefits during these cool weather periods.
No, but let me explain my logic. At the temperatures I am seeing in the engine (150F) the difference in viscosity between 20W-50 and 100W is negligible. If anything, the 20W-50 is less viscous at 150F.
I am currently running down a situation that I am seeing lower oil pressures in colder weather with a straight weigh oil when the oil is warmed. Reducing the oil viscosity, in theory, will make the situation worse.
If any of my logic is flawed, please call it out. I am not an expert here, just applying what I have learned previously. My end goal is to figure this out and get back to a healthy operating condition.
Chad
Low Oil Pressure
Great call out Tom. The pressure relief completely slipped my mind.
On my RV6 O-320 160HP I had to replace the Oil Pressure Relief Valve Spring and ball with a new one. It was an older engine and had about 1,500 hours on it since new. This brought the oil pressure up to normal and has not been a problem in the last 200 hours at 80 PSI.
From your description, the ambient temps seem coincidental. Likely the reduced oil pressure is coming from some other source/problems. Pressure relief is a good place to start and verifying the sender accuracy with a mechanical gauge is also a good idea. Several potential causes for sudden oil pressure drop, but best to start with things that are easily fixable before going to those that are not (oil pump, internal leakage, etc.)
vernatherm is not likely to cause pressure drop.
at 150* OT, pretty much all of the oils are going to have a somewhat similar viscosity and OP differences will be minor. 50 weight (i.e. Victory 100) and 20w50 should be VERY similar at 150. Your change is MAJOR and it is too large to be related to oil viscosity/temp IMHO.
Larry
at 150* OT, pretty much all of the oils are going to have a somewhat similar viscosity and OP differences will be minor. Your change is MAJOR and it too large to be related to oil viscosity IMHO.
Larry
I agree with you Larry. The only reason I am even looking at the vernatherm is that the oil cooler shutters are making a difference even before it gets up to 170 degrees or so. I am surmising that the vernatherm is stuck open letting oil constantly circulate to the cooler, which would drive the lower oil temps that I am seeing. Still secondary to the oil pressure issue though.
If the gauge checks out, I would take a look at the suction screen. If it is restricted the oil pressure will be lower when the oil is thicker and colder at higher RPMs when the demand to the pump is greater but be normal at idle when the demand to the pump is lower. sounds like what you have...
Good Luck,
Mahlon
Normal OAT above 80
340 SMOH
I don’t know the difference in oil filters, but for my o320 D1a, I use Tempest 48110-2 Most all o320 use this per tempest.
Easy change to see if a difference appears. I don’t think it’s temp related. Pressure sender is always my first check when pressure(s) change on my RV. If FL is your normal/majority area of flight, IMHO , you should use a multi viscosity oil always, Victory 20-50 is good stuff.
https://tempestplus.com/wp-content/uploads/2019/09/Oil-Filter-Application-091019.pdf
My understanding is the only difference between the 48108 and 48110 filter is one has a male thread and one is female. My adapter was designed for the 108 or 109 female threaded filters.
Vernatherm doesn't completely block the oil so the shutters with still have an effect. In the great white north I have to block the oil cooler off by 75% to get close to 180, and even then it's hard to keep it there at ECON cruise LOP.
Thanks Tim. I didnt realize that there would still be some flow. I thought that below the set temp the vernatherm closed down tight. I have a laundry list of things to check this weekend.
The filter adapter on the acccesory case may or may not have an internal filter bypass.
No adapter bypass? Then the filter itself must have an internal bypass.
The 108 filter has the bypass built into the filter while the 110 doesn't.
There are hopefully no installations without bypasses in the adapter and using 110s with the male threads sticking out of the filter baseplate.
Close out
Just to close the issue out. I removed the oil pressure relief assembly. While it was relatively clean, the ball bearing had some scoring, most likely from the interface with the spring as well as some minor pitting. I ended up ordering a new 1028-B, the ball bearing, and the oil pressure is back to normal.
I can only surmise the ball bearing rotated to a position where the scoring or pitting was preventing a good seal to the block and was allowing a significant amount of oil through the bypass.
Thanks for all of the thoughts on what it could be. It really helped validate my troubleshooting.
Chad
