Nick Leonard
Member
I have had an on-going issue with the standard electric fuel pump with 500 hours on it. The symptoms are that it won't always run when the engine is cold. This occurs only in about 1 in 15 starts and it always seems to operate while the engine is running (verified by increased fuel pressure). I don't recall having the problem when the engine was warm but I can't say absolutely. Outside air temperature doesn't seem to be relevant. The problem does not seem to be getting worse.
I have checked the wiring for a poor connection but nothing obvious. I have pulled the pump and bench tested it without getting it to fail. Is replacing the $500 pump the best option at this point?
Anyone else had this problem?
