Keep VAF
Going
07-02-2022, 04:47 PM
Originally Posted by Northernliving
Bill, this looks really nice! At what RPM will this start generating power? The B&C pad mount pics up around 900-1000 rpm. How does yours compare?
Originally Posted by monkworkz
You'll get 15 amps at around 1000 RPM, over 1800 you get 30 amps.
Bill
Are these engine or alternator/generator RPM?
Bill
RV-7
07-02-2022, 06:21 PM
Both are crank RPM, so around 1000 RPM crank RPM you'll get 15 amps, 1800 crank RPM you'll get 30 amps.
07-16-2022, 06:16 PM
Bill,
Will you be at Osh 2022 with a sample of the Monkworkz Generator?
Charlie
RV-8
07-16-2022, 06:32 PM
I can report the Monkworkz generator on my RV-8 works perfectly.
Carl
07-16-2022, 06:39 PM
Monkworkz at Oshkosh 2022 thread
John Bright, RV-6A, N1921R, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
07-16-2022, 10:00 PM
Originally Posted by johnbright
Thank you John
Charlie
RV-8
07-17-2022, 10:35 AM
Works great
Just finished the install. Instructions are excellent and it does exactly what it is supposed to so. Support has also been excellent. Quite happy to replace my SD-8 with this.
RV-8a Flying
RV-10 Building
J-5A Flying
Extra 300 flying
07-17-2022, 12:14 PM
Originally Posted by Chkaharyer99
Bill,
Hi,
Yes, I'll bring one along for people to check out.
Bill
07-20-2022, 12:25 PM
Hi Jesse,
Yes, I am working on a belt driven version. There are some mechanical hurdles so don't expect anything for quite some time but it is my intention to make one that runs on the front of the engine.
Bill
Doubling down on the request for this from us RV-12 people who live in a perpetually weight-constrained world.
The output of the standard Rotax 912 ULS electrical system is limited at 15 amps, so a backup with significantly more power would be incredible.
An even better solution would be a mount which interfaces with the currently-empty vacuum pump mount on the back of the gearbox, since this would avoid having to modify the cowling to accommodate the belt drive. On the RV-12, this would need to take into account the pitot connection block, but that can probably be solved with a unified bracket which combines both functions.
07-24-2022, 11:58 AM
Thanks for the reminder, this is for sure something I'd like to tackle. I'll send you a message.
Bill
Thread Tools |
Display Modes |
