VAF on Twitter:
@VansAirForceNet
Old 10-03-2022, 05:51 PM
gregfuess gregfuess is offline
Default Most Commonly Applied Primers
I would start a poll, but I don't know the most commonly applied primers to include in it. While I live in arid and dry New Mexico, I plan to fly to coastal areas. And for general good practice, want to prime the interior.
While I prefer rattle cans for convenience, I am not against using a LPHV applicator and two part primer.
Also thinking a good surface prep would do no harm either, but don't know what kind for that, either. I've reached out to a few companies, AKZONobel and ZipChem, and getting a response is difficult. ZipChem did respond, but the rep copied lots of people, and I got lots of different responses. Not a consensus answer, which was a strike against them.
Any advise appreciated. Ordered all kits at the end of February, and the wing kit arrives first, and tomorrow.
Greg Fuess
Albuquerque, NM
N521GF
Working on an RV-14
Old 10-03-2022, 06:00 PM
terrye terrye is offline
I used Henkel's Alumiprep (cleaner) and 1201 Alodine (conversion coating), followed by PPG Super Koropon fluid resistant epoxy primer. Very satisfied with the results but it is a LOT of extra work. I don't think a rattle can primer can in any way compare. You'll need an HVLP gun (might as well get a good one).
https://krayden.com/technical-data-s...al_data_sheet/
https://www.ppgaerospace.com/Product...nt-Primer.aspx
For the cockpit I used Sherwin Williams Jetflex WR applied over top of the epoxy primer. Did this with the individual parts before they were riveted together and like the results.
https://industrial.sherwin-williams.....10662939.html
Terry Edwards
RV-9A (Fuselage)
2022/2023 VAF Contribution Sent
Old 10-03-2022, 06:04 PM
Stewart makes a couple primers that some people use. I use their Ekopoxy sometimes.
Dave
Old 10-03-2022, 06:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Primers
If you don't mind dealing with the PPE, it's pretty hard to beat SW P60G2. Easy to shoot. Very light. Second choice would be an epoxy 2k primer.
If you want a water based, Stewart Systems is the top choice.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 10-03-2022, 06:29 PM
skelrad skelrad is offline
Default Stewart Ekoprime & Ekopoxy
I vary what I use depending on the area (and my mood). I've used Stewart Ekoprime for just about everything though. I love the fact that there is no real "pot life" like an epoxy primer, so if I have any left over, I can save it for the next spray session. It may not be as tough as epoxy, but for interior parts that never get touched or see the light of day after they're built, it works great and is very easy to deal with. I do keep a few rattle cans around for the random small parts when I don't feel like pulling out the spray gun. The rattle can approach is definitely not as tough as the Ekoprime, but again, I fail to see it mattering in most interior cases. That being said, I am switching over to Ekopoxy for interior cabin priming since that area does get touched and beat up over the life of the plane. I will have a full interior covering most of the cabin area, otherwise I would top coat with paint to get the ultimate in durability.
Brandon
RV-9A: Fuselage in progress
Old 10-03-2022, 06:50 PM
lipper03 lipper03 is offline
Since I’m doing QB fuse and wing, on the EMP so far I’ve done prekote wash and SEM’s ezcoat rattle can. I did testing with a few others and liked ezcoat. Because I’m not doing fuse and wings myself, is why I stuck with rattle can.
Brian
RV-14A
Build Started 12/31/21-
Section 6-9 complete 11/17/22
*Emp Ordered 9/27/21- Delivered 6/30/22
*QB Fuselage Ordered 11/3/21- Est 2Q23
*QB Wings Ordered 2/18/22- Est 3Q23
*YIO-390-EXP119 Engine Ordered 5/14/22- Est 2Q24
*Prop Ordered 5/20/22- Est March 23
*Finishing Kit ordered 6/25/22- Est 3Q23
https://eaabuilderslog.org/?s=RV14A2021
PA-28-236 N419SB
KIWS
VAF donation 2021/22/23
CAF Member
EAA Member
AOPA Member
Old 10-03-2022, 07:45 PM
Everwild Everwild is offline
Default AKZO Epoxy Primer
I'm using the Akzo epoxy primer and am very happy with the results. Coating seems bullet proof once cured. Can even dimple after priming and it doesn't chip. The product I'm using is 463-12-8 and CA-116 for A and B.
I scuff with Scotchbrite and a pre-treatment called PreKote. Probably an overpriced degreaser but it has worked well. Some have mentioned using Bon Ami as a suitable degreaser. I think the key is to get your parts as clean as possible and scuff the surface adequately so the coating adheres mechanically.
The 3M Accuspray system is a game changer IMO. No cleanup to speak of which means less exposure to fumes etc. The 3M gun requires a fair amount of air volume so you'll need a decent sized tank on your compressor for large parts.
Use high-quality PPE and build some sort of booth to pull the vapors out. I'm fortunate in that my shop is not attached to the house. The fumes are strong even with good ventilation. It cures fast so I try to spray outside when the weather is suitable.
I also purchased two Rockler Mix Mates to store parts A and B. Allows me to mix them without being exposed to the fumes and makes it easy to pour out the right proportions without making a mess or wasting it.
Cons, it's somewhat expensive. I found a guy in Detroit that will sell it for $200 for a two gallon kit. AKZO lists distributors on their site so you might be able to find a seller near you. Spruce was like $400 and SkyGeek was over $300 + shipping last time I looked. I also wish the AKZO was a grey vs green. Unless you're going for a military look it's pretty ugly but it will be covered up for the most part.
Prepping and priming adds a fair amount of time to the build. My guess is 10-15% of my time is spent scuffing and priming.
David Woodward
Holland, Ohio
RV10
Working on the wings
2023 Dues Paid
Photos of build progress here.
Old 10-03-2022, 08:07 PM
Any recommended, or the same question in a roundabout way, which are you using now?
Greg Fuess
Albuquerque, NM
N521GF
Working on an RV-14
Old 10-03-2022, 08:11 PM
Any estimates of how many gallons you'd need to completion?
Greg Fuess
Albuquerque, NM
N521GF
Working on an RV-14
Old 10-03-2022, 08:26 PM
My guess is 4 gallons total. 2 kits. Maybe more? I used most of a set on the empennage, but, I think I had the air pressure dialed up higher than necessary when I was learning how to use it. I was making a lot of overspray. The finish looks great but I was sending most of it through my spray booth. There's a balance between getting good atomization and wasting primer.
David Woodward
Holland, Ohio
RV10
2023 Dues Paid
