VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-3
Old 09-13-2022, 02:36 PM
Cloudboy Cloudboy is offline
Default Need Van's instruments/ Alternator advice
Something burned up several of my Van's engine instruments; CHT, EGT, fuel quantity, fuel pressure, oil temp and pressure. I saw Stein at Oshkosh and he said he had several he had removed for panel upgrades. He generously gave me some of the ones I need. I still need CHT and EGT as well as the low pressure fuel gauge. If anyone has some laying around gathering dust, I am interested in them.
Also, is there anything other than a malfunctioning voltage regulator and/or alternator that could have caused the damage? I hate to just replace parts looking for a problem. I have a Japanese, internally regulated alternator that is putting out 14.2 volts. I don't think a test at the auto parts store will show a problem. Is there a way to test the regulator or a simple way to add overvoltage protection?
Feel free to call me: Steve 509-991-8915
Old 09-14-2022, 11:24 AM
Untainted123's Avatar
Untainted123 Untainted123 is offline
My understanding is that all of the old "analog" gauges are simply measuring resistance across a resistor (the sensor) and correlating that to a scale with a needle (the gauge), essentially like the old voltmeters before they all became LCD displays with numbers.
So, I would imagine all of them could be ruined by over voltage or perhaps over amperage, effectively ruining the resistor (the sensor), perhaps making the gauge have to swing way past it's normal stops and ruining it. It's a theory anyway.
Most of the sensor have published resistance values for a given temperature or pressure, and can be easily checked with a voltmeter (proving which is bad, the sensor or the gauge).
Some of the old Van's gauges actually had a troubleshooting procedure for them also, read this thread for a discussion of it.
Old 09-14-2022, 06:59 PM
Thanks untainted. You are correct, many gauges are milliamp meters and the current through them varies with the resistance of the sensor. I think the problem must have been over voltage. So far, all the sensors have been fine but on autopsy, the meters themselves have melted and/or have discolored components. I was hoping some builders saved their old gauges when they went to glass panels.
When I last flew, I had a strong burning smell in the cockpit giving me a sore throat, etc. I suspected overvoltage so I kept the alternator on and watched the volt meter. I had a solid 14.2 volts; just what I expected. I assumed that a failed voltage regulator would show overvoltage on the voltmeter. I don't understand the failure modes of regulators and maybe it was just a quick spike. One melted gauge was bad enough that I seems like more than a quick spike. The plastic case was substantially deformed, some capacitors destroyed and small components melted off the circuit board. The failed gauges were wired in parallel, not series, so I don't think over current would have wiped out several at once.
I would sure like to hear anyone's ideas about voltage regulator failure modes and, especially about surplus instruments.
Old 09-14-2022, 08:02 PM
BoydBirchler BoydBirchler is offline
An overvoltage is pretty simple to add. I believe you can obtain the necessary components from B&C. It consists of a diode that has an approximate switch on value of 15 volts, that is used to crowbar (short out) the 2 amp field breaker.
Old 09-15-2022, 10:44 AM
Good advice Boyd. I ordered a B&C alternator and regulator yesterday. I'm still looking for instruments.
Old 09-15-2022, 10:57 AM
Mikeyb Mikeyb is offline
Since it’s The engine mounted instruments and they saw a massive overcurrent one might suspect the Engine/airframe ground degraded and caused the starter/alternator current to return through the engine instruments.
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Phase 1 complete 10/29/22
KAJO
Old 09-16-2022, 01:19 PM
FinnFlyer FinnFlyer is offline
Note that this requires an alternator with external regulator.
Having said that, I'm actually using a Mazda RX-7 alternator and its internal regulator where I was able to disconnect internal supply to the internal regulator and supply it from circuit breaker with over voltage crowbar. Depends on alternator design if that is feasible.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 09-24-2022, 09:31 PM
FireMedic_2009 FireMedic_2009 is offline
You can add another contactor to run the the B-lead through it from the alternator and use the over voltage protection module to trip the contactor. You need to understand what you are doing and how to connect it.
RV-6A IO-320 FP sold
RV3B O-320 160hp
Donated 2018 and continue annually
