Prop tape re-glue on Catto?
NM Doug
The prop tape on our Catto is coming off the back edge of one blade. Catto refinished the prop and redid the tape in 2021 - the rest is holding up fine.
Is there a way to batten this down again, especially since it looks like it's separated from the leading edge some? I wasn't up for doing the re-tape myself back in 2021, and because the prop itself needed some cosmetic TLC, I sent it in. Ideally, I'd like to avoid either sending it back in already or redoing the whole tape.
I had some of the tape coming off on my Catto, not quite as large an area as you picture. I called them and they said to glue it back down with superglue. Has held up for many years since.
