Old 11-28-2021, 10:20 PM
Michael Seager Michael Seager is offline
Default How to make an RV fly really bad!!!!
I took my first RV flight in 1983 so I guess that means I have been flying RVs of all models for at least 38 years. I have helped a lot of people over the years either inspect and test fly or deliver and help check out a lot of people in their planes. I have test flew over 200 brand new RVs and flown more than 400 different airframes of all models of RVs. I have extensive time in all models except the RV-1. Last time I checked my logbook I had well north of 20000 hours in RVs.
I was ask to inspect and deliver an airplane this last weekend. I went and looked at it as I have done many times over the last 38 years. It was a very nice built and finished airplane, professional painted. On occasion I find an airplane that really stands out and this one was not in a good way.
This plane was so touchy to control that it was a handfull to fly even with all my experience. I seldom write on this forum but hopefully this will help some one else have a better flying plane. I have preached this to my students for many years. These two things will improve how your plane flys a lot. This will apply to RV-3 4 6 7 8.
1 Do not cut 6 inches off your control stick. It was designed to be the length that it was shipped in the kit. If you want to cut it down to put on a stick grip make sure you put back to the original length. Nothing I can think of worse than trying to negotiate a strong gusty cross wind with a touchy airplane that has the stick cut off to down between my legs. If you think I'm wrong on this take the steering wheel off your car and replace it with a 4 inch steering wheel and see how it goes. Van has wrote several articles on this and yet I still find lots of planes in the field that have really short cut off sticks. To make things even worse go to high altitude and load up the baggage compartment to make a rear CG and you have a really touchy hard to fly airplane when you cut the stick off. Over the years I used to carry some stick material with me so i could extend the stick back to the proper length before i ferried an airplane.
2 Make sure that the trailing edges of the ailerons are squeezed properly. This one very simple to fix item can make your ailerons nasty to fly. I find this a lot when test flying new planes. The trailing edge does not get squeezed enough and it makes this thing called aileron snatch. Aileron snatch makes the aileron very sensitive and unable to center. Give me 10 minutes and a hand seamer and I can fix this. A straight edge and a hand seamer can fix promptly. The particular plane that I delivered this weekend had terrible aileron snatch. Interesting that this plane had flown 700 hours this way and the original owners thought it flew great. I let the new owner fly it before I fixed it and he could believe how much different it flew.
I wonder how many other airplanes out their fly like this one did and could be improved a lot.
Michael Seager
rv6cfi@hotmail.com
Old 11-28-2021, 10:26 PM
mfleming's Avatar
mfleming mfleming is offline
Thanks for the great report and tips Mike.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2022 and so should you
Old 11-29-2021, 12:08 AM
gotyoke gotyoke is offline
You have me extremely curious as to why these two things apply more to the 3 through 8 models and less to the 9 through 14 models.
RV-14A - N74LF reserved
Emp started 1/1/2022 - 65% done
Wings SB started 4/14/22 - 15% done
Fuse ordered
Old 11-29-2021, 01:42 AM
The models listed have ‘folded’ trailing edges on the ailerons. The 10 and 14 have 2 piece, riveted trailing edges, which cannot be squeezed.
Old 11-29-2021, 01:48 AM
pgroell's Avatar
pgroell pgroell is offline
Default My experience too
Regarding n°2 : I flew my RV-7 for 8 years with very light ailerons without this being a problem to me, I then participated in a formation training camp and a pilot I was flying with told me that the ailerons were indeed very light (which did no help maintaining position). Inspection on the ground showed some pillowing between the aileron ribs and a too great radius at the trailing edge.
I did some trailing edge squeezing, progressing slowly with some test flights between each iteration.
Once satisfied, I felt initially that the ailerons were a bit heavy but after a few flight the feeling is that roll control is much better and that the pitch an roll axis are better balanced.
Pascal
RV-7A #72588 - F-PSGA
VAF #484 - Donated 2022
Flying
www.notreavion.net
Old 11-29-2021, 02:42 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
in 38 years = 526hr/year. Congrats on those impressive figures
And thanks for those 2 golden tips, let's hope present builders are listening
- ain't the Destination, but the Journey -
www.aerofun.ch
Old 11-29-2021, 05:19 AM
Walt's Avatar
Walt Walt is offline
If I may, add the elevator TE to that list, I've "fixed" a number of twitchy auto pilot problems the same way.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Sam_B Sam_B is offline
I’m not flying yet, but this thread has grabbed my interest. I realize that this is probably a progressive adjustment, but is there a ballpark number for a radius that we should be aiming for?
RV-8
80% done, 80% to go.
2022 donated
Old 11-29-2021, 05:26 AM
goatflieg's Avatar
goatflieg goatflieg is offline
Mike, thanks for the tips. I found it necessary to cut my RV-8 stick down to clear the bottom of the panel; I have the stick grip positioned so it just barely clears. Bruce Bohannon's RV-8 has a welded-up stick with an aft offset. When I trained with him, I made a habit of holding the stick low so my grip would approximate what I have on my aircraft. It will be interesting to see if it gives me trouble once I'm getting formation training.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - Currently in Phase 1
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2022... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 11-29-2021, 06:25 AM
NYTOM's Avatar
NYTOM NYTOM is offline
Thumbs up Eye opening
I’m sure this post will have a bunch of us wondering where our planes fall in this trailing edge spectrum. In my quest to get the optimum qualities out of Vans design, does anyone out there have before and after photos of a corrected poor trailing edge. If anything, just to compare our edges to a property formed edge.
There’s most likely a lot of RV’s out there that could be greatly improved and much safer.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP. KJNX
