5702-75-060 washer
sblack
My rv4 plans call out 5702-75-060 washers next to the spherical rod end bearings on the elevator pushrods. I don’t see these on the Spruce sight. I can’t find anything on google that tells me anything special about them. Are they just steel washers with non standard thicknesses? My kit is pre 1990 and it has passed through other owners so I have no nice organized hardware kit. Can I substitute AN washers if I have a good fit?
The overall diameter is smaller than an AN960 and it fits closer to the centre of the ball fittings allowing a bit more rotating action. I went through this exercise when I found some missing from the aircr
aft I bought
Thank you for the link. I'll need this down the line as well. I entered the number in the search box and it came right up after I removed the leading "0" from the "060", so 5702-75-60. They are also available directly through Vans for $0.22 each, but that relates to about $10 with shipping :p I'll wait until I place a bulk order with them. https://store.vansaircraft.com/washer-5702-75-60-flat-washer-washer-5702-75-60.html
