What replacement EGT probe for AFS 3400
Notso
Member
I've been having intermittent problems with reading from my #2 EGT probe and it's just now stopped reading at all. I've searched through the AFS manual and all it refers to is "P/N 40200" but no brand is given.
Using that part number comes up with all sorts of probes on Aircraft spruce but nothing that seems the same. Does anyone know which is the correct probe to replace the existing one with?
Its an RV-8 with an O-360-A1A motor.
Thank you for your help!
I believe the Advanced system uses Dynon probes, right? The leads are yellow and red..
Call AFS directly and they'll fix you up...
