dustin_96
Member
“Machine countersink the 5 screw holes in the T-0006–L attach bracket to fit a piece of aluminum that has been dimpled for a #8 flush head screw.”
Since the nut plates are already installed, I’m thinking to follow the same procedure used in countersinking the main spar that already had nut plates in place. Step 13-03 step 5 has you use a #30 cutter so that it centers in the nut plate. Is that the appropriate procedure? I can’t think of any other way to do it.
