Fuselage jig
Do 8's still require a jig to build them?
The short answer is no. However the main alignment structure are the longerons and you need to make sure both of them are symmetrical to each other. The prepunch skin and ribs should hold things into alignment but all the final rigging alignments are measured from the longerons
