Originally Posted by rk2436
The Aeroled Pulsar NSP tip position/strobes should have a solid white light facing aft. What tip lights do you have?
Correct.
Turn on nav. lights only (no strobes), at night and stand behind the airplane. You should see a white light on the back of each wing tip. The regulation doesn't require it to be a single while light source at the rear of the airplane. Only that the white light be visible on a 140 degree arc around the back of the airplane. This can be met by placing one on each wing tip.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips,
ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR, EAA Technical Councilor
