Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
12-10-2020, 08:15 AM
912 Oil Pressure
We had a sending unit failure on our RV12, replaced it and changed the oil at the same time. Now we are only getting oil pressure into the yellow zone on the Dynon. Our mechanic is confidant everything is set up right, but doesn't have an idea why the pressure is reading low. Any ideas out there? The engine sounds perfectly smooth and we have run it up to proper oil temp to run it at 4000 RPM - but still no readings in the green.
12-10-2020, 08:55 AM
I think the first thing I would suggest is to place a mechanical pressure gauge on the oil line so you can actually verify that the oil pressure sensor is really reading low.
If the pressure sensor is actually reading low, would check the wiring and if that checks out OK ... must be a faulty sensor.
John
http://www.dogaviation.com/
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2023
12-10-2020, 09:52 AM
pressure?
What is the actual pressure value showing on the gauge? (need more data than green or yellow)
Agree that a mechanical gauge could be used to verify the pressure per the above post. Another easier and safer way (no need to run engine) to check the sender is to remove the new oil pressure sender from the engine (but have the wiring connected) and hook it up to a compressed air source. Vary the compressed air from zero to 100 psi referencing the gauge on the air compressor and compare the corresponding efis oil pressure value.
Also check that the correct oil has been used. Rotax approved is Aeroshell Sport Plus 4. And that the oil intake system was purged of air, normally this is not required if the oil cooler has not been drained.
The mechanic could also check the oil pressure regulator spring and ball/plunger. There is a hex head plug under the oil pump housing near the oil filter. Be careful to not strip the fine thread when re-assembling. I don't think this will be the cause of low pressure unless the spring has failed or it has become jammed open.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
12-10-2020, 10:14 AM
You might also need to check your pressure relief valve. Do a search here about mushroom head oil relief valves. I believe Cammie Patch was the author.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
12-10-2020, 11:06 AM
912 oil pressure
You might check with Dynon, i changed my fuel pressure sender and had to update HDX to include new part number. Now pressure indicates correctly, just a thought
01-01-2021, 04:27 PM
Thanks all. We did install a mechanical pressure gauge and the oil pressure is perfect. Rotax suggested we got a faulty sending unit, and sent us another one. Same issue. Must be something with the Dynon interface. Our mechanic is having problems getting good support from Dynon about this.
Until we can get resolution, our mechanic installed a automotive oil pressure gauge. The only issue with that is that the Hobbs meter doesn't work. (which - for the members of our flying club....is the best news EVER!
David Wilkins
N120MK
Back 40 Flying Club
Fort Wayne, IN
01-01-2021, 05:13 PM
Originally Posted by dwbuckeye
We had a sending unit failure on our RV12, replaced it and changed the oil at the same time. Now we are only getting oil pressure into the yellow zone on the Dynon. <snip>
If your engine is a 912iS Sport, potential for reduced oil pressure readings is a known issue and is caused by a design change in porting; the oil pressure sender on the ULS receives filtered oil (located just 'after' the oil filter) and on the iS the sender receives unfiltered oil (located just 'before' the oil filter). The fix is straightforward; remove oil pump and clean the screen. Recommend contacting Dean at Lockwood for details.
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
01-01-2021, 06:31 PM
Thanks all. I'll pass this on to the mechanic. Ours is not an iS.
David Wilkins
N120MK
Back 40 Flying Club
Fort Wayne, IN
01-01-2021, 10:08 PM
Oil Pressure Sensor
check to be sure you have an exact replacement. A quick check on-line indicates that this sensor was changed on newer Rotax 912 engines. Perhaps you have a newer style sensor that is not compatible with the Dynon EMS. Dynon can probably also provide some guidance. I have had newer fuel sensors on the 912 not work correctly with the EMS.
Greg
Analog Man Living in a Digital World
Donation December 2020
01-03-2021, 10:49 PM
Mine has always sat in the middle of the green band at about 50 psi +/-5 except when my oil pressure sensor went belly up.
Thread Tools |
Display Modes |
Hybrid Mode
