Torque setting for Ma 3A carb?
lndwarrior
I've searched the Lycoming Torque Limits, SSP-1776, as well as the MA 3A carb manual and cannot locate a torque for the four screws that mount the carb to the sump.
Appreciate any input or reference!
Thx
Gary
Torque setting, 5/16" nut
Look in the Lycoming Service Table of Limits SSP-1776 (attached here), section 10 of the Overhaul Manual. There is no specific torque called out, so use the standard torque listed on the second page of the attached file (Standard Torque Limits) for a 5/16" diameter bolt/nut. Also, be sure to install a new star washer under the nut.
View attachment Lycoming Srvice Table Limits.pdf
Awesome.
Thank you!
