Can I ask the VAF brain trust for any thoughts on the following problem on my friend's RV-7.
He has a Titan DIOX-370-A4L2T with around 400 hours from new. Every now and again in the cruise the fuel pressure drops to around 10 psi. As he has an AFS EFIS Jennifer reminds him the fuel pressure is low. The boost pump always restores the fuel pressure. Normal cruise fuel pressure is around 23 or 24 psi. With boost pump on it rises to around 28psi. When the fuel pressure drops it is clear the engine is running lean from the temperatures. He is reasonably sure the pressure drop is real.
The question is what is causing the fuel pressure to drop? It only happens occasionally, after using the boost pump for a few minutes the pressure from the mechanical pump will be back to normal. Until the next time it takes a dive which may be 30 minutes later or after a few hours.
Has anyone seen anything similar? What cured the problem, is it new fuel pump time or could there be another reason?
Any thoughts gratefully received, Pete.
